Airmatic Height Settings
Old Jul 8, 2022 | 04:09 PM
Frenetic's Avatar
2023 S500
Is there a different height setting between comfort and sport? If so, can I manually lower it while in comfort? I tried to manually lower it with the suspension button while in comfort but it didn’t move.
Old Jul 8, 2022 | 04:58 PM
z28lt1's Avatar
C450, GLS 63 and a few other things
The manual has good information about this. Yes, there is a height difference between comfort and sport. No, you can't lower it beyond the selected drive mode (outside of exit settings and lowering the rear from the trunk).
Old Jul 8, 2022 | 05:04 PM
Frenetic's Avatar
2023 S500
Do I have to put the entire car in sports mode or can I just change the suspension setting?
BMW allows different height settings regardless of mode.
Old Jul 8, 2022 | 06:00 PM
de31p5's Avatar
GLE53
My 53 I can change the suspension to to sport or sport + without affecting any of the other setting. e.g. I can be in comfort and switch just suspension to sport +
Old Jul 8, 2022 | 06:10 PM
z28lt1's Avatar
Yes, just the suspension is what needs to be set, not the entire mode.
Note that you can RAISE the vehicle (below 87 MPH --to the off road setting) without changing suspension modes. Just can't lower it for reasons only known to MB.
Old Jul 8, 2022 | 09:12 PM
Ron.s's Avatar
2024 GMC Canyon Denali..... 2018 Audi SQ5
Or you can set the “I” mode to all C except suspension to S/S+ and run in I.
Old Jul 8, 2022 | 09:21 PM
Frenetic's Avatar
2023 S500
Is there a way to lock in a drive mode so it stays that way at startup or am I destined to manually change it every time I start the car?
Old Jul 8, 2022 | 09:25 PM
Ron.s's Avatar
The only way is to purchase a 3rd party patch…as I recall there is one. Might be RJA-
https://mbworld.org/forums/gle-class...coded-rja.html
Old Jul 8, 2022 | 09:44 PM
jaxslk's Avatar
2025 GLE 450, 2022 AMG GLE 53
That's how mine is coded. Starts up in I* mode with my custom settings, and the automatic s/s is set to "remember last setting", which is "off" for me.
Old Jul 8, 2022 | 09:47 PM
Frenetic's Avatar
2023 S500
Does this “remote coding” get wiped after any software update? I have to recode my BMW after every software update. It’s not a big deal as I could do it myself, but this coding requires a third party.
Old Jul 8, 2022 | 09:54 PM
jaxslk's Avatar
It's certainly possible - in the 4 months I've had my car the only update I have done has been to the navigation maps. None of the custom tweaks were lost. The coding company I used will stand behind it and make the changes again if they happen to get wiped out. You'll probably find the same with anybody who does the coding for you. It's not convenient, I'd agree.
Old Jul 9, 2022 | 09:57 AM
mikapen's Avatar
Ask your coder, or search the forum.
Old Feb 20, 2025 | 05:02 AM
HEKI82's Avatar
PHEV GLE 350DE 2024 is same hight level between comport and sports what I check this country of manual. Sport mode is also become -1 when speed reach 140km/h as comport mode.
