Dash cam
Old Oct 31, 2022 | 10:39 AM
CMFUSA's Avatar
GLE350 (2021), 991.2 (2019)
Originally Posted by BACnMercedes
Ok I need help here. Has anyone seen this photo of the wires on the GLE (I’m assuming they will be similar on an e class too)
Sorry for the late reply:
Old Oct 31, 2022 | 10:55 AM
TonyF61's Avatar
2022 GLE 450
Originally Posted by jaxslk
Whoa! Close one! Glad you were not hit.
Thanks, hope the other driver is fine.
Old Oct 2, 2023 | 01:35 PM
Taherzasd's Avatar
Benz Sedan 2018
I have the Mercylion A10-2CH hidden dashcam in my Benz and I really like it. The camera hides really well by the mirror and the rear camera can't really be seen thru the tinted rear window. The wires are easily tucked away to hide them.
The video quality is really good. The quality is adjustable, which determines how much (time) you can store on the microSD card.
Old Oct 2, 2023 | 03:20 PM
mikapen's Avatar
The highest rated dash cams prices are centered around $100, most with 1080p and above resolution.
Lots of pushback from the Name Brand cams because they don't do well against the knockoffs.
It seems like lots of them have the same specs, which makes me think they're the same innards with different color housing.
Surprising what you can get for 60 bucks now.
Old Oct 2, 2023 | 04:53 PM
wildta's Avatar
GLE 580
If anyone here cares about image quality, I highly recommend looking for one with a Starvis 2 sensor. Many of the highest rated cameras have this sensor. Obviously it won't install as slick as the above camera but at least the image quality will be good.
Old Nov 17, 2023 | 09:05 AM
Bussellkdor's Avatar
LeMond
I've had similar issues with my Mercylion dashcam for Mercedes in the past, and it's usually a problem with the wiring. It's possible that the wire for the rain sensor is touching another wire, which is causing a short circuit. This could be preventing the rain sensor from working properly and could also be causing the dash cam to receive power from an unintended source.
Old Nov 22, 2023 | 05:42 PM
  #32
RossiM's Avatar
GLE AMG53
What is the on-board camera supplied by Mercedes in an optional configuration?
