AMG Active Ride Control?
This is the warning that popped up on my normally flat cornering GLE 53 as it started leaning a lot in curves. I don’t recall anyone else reporting anything similar.
Im not very familiar with these cars yet, but it sounds like the active anti-roll “bars” or stabilization failed.
https://www.caranddriver.com/news/a2...3-photos-info/
It turned out that I had moved the alignment at the left rear, so it moved as I drove, after the incident.
The ride was like I had no suspension at all - Rock hard.
Had it towed to the dealer.
Realigned, replaced an alignment bolt or two, just in case they stretched, and I'm back on the road.
It wasn't the active suspension.
As an aside, my interpretation of that display in your left cluster, is that it's not related to G-Force, but instead it's related to the center of the Earth. Otherwise known as the camber of the road or super-elevation of the corner.
I had both the g-force display and the level display going, and they seemed unrelated.
ARC is also much more elegant solution than the competition, fewer moving parts, and more direct control.
Also an improvement in simplicity, compared to previous Mercedes implementations.
https://mbworld.org/forums/gle63s-gl...ml#post8470624
I'm still wondering about what the car uses for input.
From that second link in my post, it seems to say that there are two actuating motors at each end of the car, not one motor with two planetary gears.
Plus, the active diagram on my center display shows two separate activators, each controlling their own sway bar. I have also seen the claims of 800 foot pounds aimed at each corner.
So I still wonder how many step motors there are at each end, and what the car uses to activate them. I suspect all the usual body roll and acceleration sensors, augmented by a velocity sensor that determines the speed of suspension movements.
Wheel acceleration can be calculated as the second derivative of wheel position over time, in reference to a comment from the second link above.
In addition to camera inputs, the standard vehicle dynamic control system inputs are used, same as for all cars with vehicle dynamic control systems such as ESP. This means substantially all passenger cars.
Primary inputs:
steering wheel angle
gas pedal position
Primary measurements:
vehicle speed
yaw rate
lateral acceleration
roll angle and roll velocity
transmission gear status
…plus more
From these the active stabilizer bar software decides what actuation, if any, should be done by the hydraulic (Active Curve) or 48V (AMG Ride Control) actuator.
One actuator per axle. Two total actuators per vehicle, if the active roll system is installed on both axles.
Not two actuators per axle.
The display on the left is showing degrees of body roll and % grade.
I'm not sure I've ever seen a real paved Road that doesn't have super-elevation in corners, and 7% on a 50mph corner is about right. On some of those tight freeway flyovers, I wouldn't be surprised at double that
I agree, there's no way you'd see that much lean on an ARC car. The tires would let go first.
Try a curve on flat ground, 2 lane road and drive slowly around it watching the degree reading. Then repeat on the same curve at a higher speed. See if your reading doesn’t increase the second time. Inside lanes tend to be slightly banked, outside lanes are not on the two I tested. A mountain road following a river with a 30/35 mph limit is a good example. On these, where ice is an issue, they tend to crown the center for drainage in our area.
I found a nearby corner that I could drive at different speeds and photograph my instrument cluster displays. I set left display for inclination (if that's what it's really showing) and the right one for G-Force.
Corner taken at 15 mph, near 0 g's on right display.
Same corner at 55, 0.3 g's.
Both taken in comfort mode.
I'd say the left one is an inclinometer. And, as Ron said, it's probably more for off-road use.
As far as the banking in a corner, which I call super-elevation, the next corner is a 40 mile an hour corner, and I stopped right in the middle of it and it measured 7° banking. Had to scoot to get out of the oncoming traffic, so no photo there.
