2020 GLE350 rear alignment problems
oh and current setting are -1 34 left and -1 56 right
I think some of the alignment bolts are single use bolts, if that affects anything you're doing.
Lack of OEM adjustment has been brought about through cost cutting and ever increasing speed of Auto assembly lines.
Earlier models that have OEM Camber and Caster we provide extra adjustment (also majority of kits are designed to replace at same time the 4 front and rear highest wearing bushings).
Current models the often quoted reassuring “Full Front & Rear ‘4’ Wheel Alignment” is only Toe (directional) adjustment. No essential Camber to allow to adjust tire contact angles - spread load more evenly. Preventing costly premature replacement of tires.
Align tech can adjust Toe all he wants but it is not going to resolve excess edge wear brought about by day to day commuting encountering high cambered roads or wheel squat through load carrying or lowering. Plus the frustration of no adjustment to cater for curb knock damage.
All align tech can do to try and placate is to state - “have adjusted to factory specs”.
Owners then going from one dealer or align shop to the next or experimenting with changing tire brands.
FOR ALL GLE V167 WE THEREFORE MANUFACTURE:
REAR CAMBER (and Extra Toe to compensate) upper adjustable control arms. KMAC are precisely adjustable on vehicle and are heavy duty designed for extreme conditions. Unlike other brands not soft extruded aluminum#504226N $695
FRONT CAMBER & CASTER Upper ‘A’ arm inner bushings. Precisely adjustable. Design retains the original hi strength forged alloy OEM arms. Bush extraction tool included. #504216-2K $480.
Worldwide delivery $40 one kit $60 Front & Rear
AUDI to VOLVO - KMAC Experience Of Resolving OEM Suspension Shortcomings Since 1964 !
