Disable tailgate from opening with key fob
Received 2,465 Likes
PFL205.064 with M276.823 (Oil pump solenoid defeated)
They should had made it a warranty issue as it was a design flaw, the keys are so easy to be accidentally pressed than previous generation key. For a used to be attention to detail company like MB, this is an oversight.
mikapen (06-19-2023)
The following 2 users liked this post by shotgun_banjo:
mikapen (06-21-2023),
Zeusmotorworks (06-21-2023)
2023 Urus Performante - 2021 Ferrari Roma - 2017 Ferrari 488 GTB - 2022 GLE 63 S Coupe
Just got my two keys done at the dealer. Works great and MB should have done this from the get go. They also didn't charge me for it.
#32
#33
Yup good for sure, on their part for not charging, makes the customer feel appreciated and probably want to take the vehicle back to the same dealership for any future maintenance service given this positive experience.
#34
Had the same issue. Buttons on key fob are accidentally activated in my wife's purse or my pocket and damaged the tailgate.
The easy solution is a hard leather case (search: car fob leather case). Cheap and very effective! We never use the push keys on the fob anyway; really, my wife never takes the key out of her purse.
#36
Received 1,598 Likes
'21 AMG53 wDPP & ARC, 19 GLC300 - Former- 10&14 ML BlueTecs, 20 GLE450 E-ABC, 15 Cayenne D, 17 Macan
I wonder if a soft leather case might also work.
These looked interesting:
https://leatherbrut.com/collections/...-leather-cover
jaxslk (07-30-2023)
#37
#38
The ones you show obviously are designed to still push all the buttons. I would assume that they are less sensitive with such a case, but the one I showed will clearly stop the issue. Having said that, I have no idea why anybody would still use the fob push buttons. Walk to the car, put your hand on the handle and it will open; get out of the car, put your thumb on the handle and it closes. Trunk has hands free open. So I never, ever use the key fob buttons. I actually wish they had the fob in the shape of a credit card to be put in my wallet - that's really all that is needed.
#39
#40
#41
personally I keep my key in one of these. No accidental presses and keeps the key signal away from thieves
https://www.amazon.ca/VONETTI-Busine.../dp/B08H5WBX3G
#42
The keyless go systems that come with our Mercedes models can be disabled simply by pressing the lock button twice. This stops the key from broadcasting altogether. However, remember that you'll need to use your key the next time you want to key into your vehicle since the doorhandle touch to unlock feature won't work when keyless go is disabled.
#43
#44
#45
Edit: I realized that you're probably confusing the other keyless go feature where the key will go into a sleep mode when sitting still for a couple minutes and then it wakes up again once it moves. This is another protection from relay thefts but it's different from double pressing lock where keyless go will not turn on again until you push a button.
#46
It cannot be enabled again without pushing a button. So yes maybe if the bouncing accidentally pushes a button but the mere jostling will not enable the keyless go once it has been disabled.
#47
Classy, too.🙁
TonyF61 (08-02-2023)
#48
mikapen (08-04-2023)
#49
I created a short 1min video how to deactivate Keyless-Go, hope this is usefull:
https://youtu.be/dM5qWFOcbQM
#50
If you want to totally deactivate all key buttons, I think only way is to remove key battery.
I have only deactivated trunk button for the main key and Keyless-Go part for the spare key.
