GLE350 - odd "resistance" issue
Old Oct 14, 2022 | 01:06 PM
aroby's Avatar
GLE350 4Matic (Emerald Green Metallic)
I've had the GLE350 for about 18 months now and in the past couple of weeks did the first really long trip in it (IL-FL-IL).
I set off in the early morning, in the rain, in N Georgia on the interstate. Lots of downhill driving. The best I can explain the issue is that the car was facing constant resistance. As I went down the hills at 70-75mph, I would lift off the throttle and the car would start rapidly slowing down. I'd need to keep on the pedal to keep the speed constant. It felt like the brakes were constantly on. I pulled off at the next rest area and turned the car off. There was no brake pad smell coming from it. I applied and released the electric brake a couple of times and set off again. The behavior was better but not completely resolved. It wasn't until I descended the 5% grades in TN just north of Chattanooga the the problem seemed to clear.
Has anyone else has experienced the same thing?
Old Oct 14, 2022 | 04:32 PM
MBguy013's Avatar
Veteran: Marine Corps
2021 GLC 300 4Matic
It is a safety thing to where the vehicle will automatically slow you down, even if your cruise control isn't enabled, especially when you're going downhill.
Old Oct 14, 2022 | 05:41 PM
BACnMercedes's Avatar
19 E63s, ‘24SQ8, wanting another gas guzzling V8
It could be that the brakes were apply light pressure in the rain to “clean” them for when you need it. Was it only during the rain part of your long trip?
Old Oct 14, 2022 | 05:53 PM
djer's Avatar
GLE350(V167) C300(W204)
How high was the RPM? Comfort / Sport / Eco mode? I have a feeling the car probably downshifted by itself, which I also notice a lot with ours when we come down our steep neighborhood hills.
Old Oct 14, 2022 | 06:45 PM
aroby's Avatar
Comfort. Going downhill. It should just coast, but it slowed down like the brakes were being applied.
Old Oct 14, 2022 | 08:54 PM
mikapen's Avatar
Is there a possibility that you had inadvertently activated cruise control at a lower speed?
That's unlikely, but it's the only thing I can think of that would forcefully slow the car.
Old Oct 14, 2022 | 09:37 PM
aroby's Avatar
No, no cruise control. I'll have the dealer check it all out.
Old Oct 15, 2022 | 09:49 AM
chassis's Avatar
2017 GLE350 4MATIC
From your other thread, it sounds like you are learning the nuances of Distronic. Is this a possibility?
Old Oct 15, 2022 | 11:20 AM
TexAg91's Avatar
2020 Mercedes GLE350 4Matic; 2023 Tesla Model Y
Was the cruise on (powered)? Make sure it is off if you’re not using it. Distronic will brake to maintain the desired speed. I’m guessing you we’re experiencing engine braking down hill to slow the vehicle-mine will do that downhill in comfort. Drive in economy mode if you want the car to glide downhill (no engine braking).
Oddly, I and others find the GLE-350 drives better in economy mode, the throttle tip in is a little more aggressive—which is counter intuitive. It also starts from a stop in 2nd gear (vice first) so the auto start feature is a lot less jarring. The second gear start is probably why the throttle tip in is more aggressive. As mentioned above, it will glide with engine on, but disengaged from the transmission.
Give it a try for a few days. It will need to learn your driving style in eco mode.
Old Oct 15, 2022 | 02:00 PM
djer's Avatar
Yes! Try in "Eco" mode and see if it replicates. The glide mode should eliminate what you're experiencing.
Old Oct 16, 2022 | 03:55 PM
TonyF61's Avatar
2022 GLE 450
I believe I read somewhere, that ECO mode is the only mode where "coasting" is possible with out transmission engaged.
Old Oct 16, 2022 | 05:57 PM
aroby's Avatar
No other car I have driven, including prior GL450s I've owned, actively slowed down going down a hill!
Old Oct 16, 2022 | 06:00 PM
aroby's Avatar
No cruise control. I just learned about the glide with Eco. Seems bizarre that engine braking would be used. As I said, this seemed to clear up after a while - it certainly didn't slow itself down going down the north side of the hills after Chattanooga. They are 5% grade and you always have to brake going down there.
