Full-Lock Slow-Speed Turning Strange Behavior
Old Nov 4, 2022 | 03:47 PM
Frenetic's Avatar
2023 S500
Anyone else feel like the front wheels slip or catch for slow-speed full-lock turns? When I back out of my driveway and nearly lock turn while driving over the sloped curb, it feels like the front wheels slip or catch. It also happens on flat ground and while driving forward. It’s hard to explain, but it does not feel natural. I only notice while going very slowly.
Old Nov 4, 2022 | 05:08 PM
PandaSPUR's Avatar
Subaru BRZ
Sounds like "crabbing"
Theres a few threads on it on this forum. Seems like a common issue with the OEM summer tires.
Old Nov 4, 2022 | 08:07 PM
Frenetic's Avatar
2023 S500
Nice. Never even heard of this issue before. I came into this car with enthusiasm and some pride in ownership. I don’t feel that way anymore. All I can is this: that Alabama plant has some major quality control issues and MB has some really lame engineers and development managers.
Old Nov 4, 2022 | 09:38 PM
mikapen's Avatar
It's a characteristic of wide tires. The wider the tread, the less the Ackerman Effect is able to compensate for turning angles.
In all turning tires, the outer tread blocks travel farther than the inners, and something slips a bit. Just like a locked differential makes the inner and outer tires fight each other.
When you release the tension by going over a curb, the tire will move.
Edit: Summer tires can be more prone to this at low temps.
Old Nov 4, 2022 | 10:34 PM
shotgun_banjo's Avatar
'13 GLK350 4matic,'10 C207,'15 GLA250,'07 Honda Odyssey, '18 GLE 43, '24 EQS 580
yup! happens to me too as well when I pull-in to my driveway. This also happened occasionally with my previous ML350 before. It feels like one tire goes on a patch of loose sand and slips. Sometimes it happens to my GLK, GLA and C-class as well so I think it is just one of those 4matic quirks. On my other cars it does not do it when I approach the same angle in my driveway. It cannot be the tires as on my other cars I have non-MO tires on it and it still does the same. That should not make you feel bad about the vehicle. I experience this on speeds like 2-5kph so very very low speed like crawling speed.
Old Nov 5, 2022 | 10:30 AM
BlueYonder's Avatar
2024 GLE 450, 2009 SLK 300
Friend of mine had a similar problem with his AMG. Turned out he was using summer tires in Maryland in January. He continued to drive the car and ended up ruining the tires. Had chunks of rubber coming off the tires.
Old Nov 5, 2022 | 02:28 PM
Wolfman's Avatar
Super Moderator
No need to be disappointed with something that isn't a problem, just normal behavior you weren't aware of.
Old Nov 5, 2022 | 03:51 PM
Frenetic's Avatar
2023 S500
I find it hard to believe it’s normal; I’ve never experienced anything like this before and I’ve owned countless AWD vehicles with “very wide tires.”
This is just another disappointing revelation about this thing. I’ve never owned a car that had this many annoying issues before. It’s really disappointing.
Old Nov 5, 2022 | 03:53 PM
chassis's Avatar
2017 GLE350 4MATIC
Ackermann error.
GLC63 has it bad.
Other models/brands have it too. Nothing can fix it, but rather only mask it.
It’s “normal” in the sense it is built into the steering and suspension geometry chosen by MB. It can’t be undone, it is a fundamental aspect of the vehicle design. Unless aftermarket hubs, knuckles and control arms are used. i.e. a new front suspension.
Old Nov 5, 2022 | 04:01 PM
Frenetic's Avatar
2023 S500
Well, to call something that has “error” in its name normal leaves a lot to be desired. Again, this is the first I’ve heard of it or experienced it and I've owned AWD Audis and BMWs without this “error.”
Old Nov 5, 2022 | 04:14 PM
Ron.s's Avatar
2024 GMC Canyon Denali..... 2018 Audi SQ5
It’s not an error but Physics. Geometry, turning radius, tires, temps all play a part. BMW want’s you back…it’s a far better POS. Life’s short get something that makes you happy.
Old Nov 5, 2022 | 04:30 PM
Frenetic's Avatar
2023 S500
According to the Society of Automotive Engineers (SAE), it is called “error.”
https://www.jstor.org/stable/44470999
Old Nov 5, 2022 | 04:32 PM
mikapen's Avatar
Originally Posted by chassis
Ackermann error.
GLC63 has it bad.
You're correct that "nothing can fix it," because nothing is wrong. See post #4.
The Ackerman(n) effect, as it refers to suspension geometry, isn't the issue. It's the 13" wide tires, which have their own inherent, internal Ackermann-like issues.
You can demonstrate this yourself by steering a naked tire across the floor. The wide tire must induce more slip to turn than a narrow tire.
If you don't have a tire available, use a milk carton, lay it on its side and again on its bottom, slide it around a "corner." There will be comparatively more slippage with the greater width on the countertop.
Perfect Ackermann front suspension geometry requires a fictional Zero Width tire.
The solution for the OP is to put bicycle tires on his car.
It's not the car, Mercedes, or those stupid engineers.
Old Nov 5, 2022 | 04:36 PM
Ron.s's Avatar
Factoids:
Ackerman is used in all regular cars and anti ackerman used in special cars like F1 cars and some sports cars. Effects on wheels. In ackerman front outer wheel have more load on it while cornering and in anti ackerman front inner wheel have more load on it while cornering.
Advantages. The intention of Ackermann geometry is to avoid the need for tires to slip sideways when following the path around a curve. The geometrical solution to this is for all wheels to have their axles arranged as radii of circles with a common centre point.
Old Nov 5, 2022 | 04:43 PM
mikapen's Avatar
The "error" exists if there are tires on a car.
Take your newfound diagram and apply the lines to a single, wide tire.
Think about that and apply it to your OP.
You have experienced it on every car you've owned. Maybe not with the tires with as such high traction or width, but it's ALWAYS there. Period.
Stick with this forum. You'll "hear of" more things that are true as you participate.
Here's a picture of the energy you released by driving over a low friction surface with your sticky tires at full lock, as you described in you OP. Slip angles and the Ackerman effect. This is what's called "crabbing." Keep studying.
Old Nov 5, 2022 | 05:05 PM
Ron.s's Avatar
Good explanation Mike. Since I put the Michelin CrossClimate tires on our AUDI, the more aggressive tread enhanced the Ackerman effect so that there is a noticeable rumble at full lock. It was also there with the OEM Michelin Primacy Tour tires backing out of the garage when cold. I never thought to complain about it on the Audi Forum.
Old Nov 5, 2022 | 06:31 PM
Frenetic's Avatar
2023 S500
According to this article, the steering dynamics can be designed to slip or not based on the geometry, or the steering angle of the inner and outer wheel (with respect to a slew of other parameters). This leads me to believe this condition is a conscience decision based in the angle differential, which is skewed more towards the Ackerman angle. I can only assume that since I’ve never experienced this or seen a post about it on BMW or Audi’s forum over the last 12 years, that they chose an angle that minimizes this vs MB.
http://ckw.phys.ncku.edu.tw/public/p...ing_Theroy.pdf
Old Nov 5, 2022 | 06:52 PM
mikapen's Avatar
What you say is true, however it doesn't apply to your original post. Read post #4.
To solve this in your own mind, take the diagrams that you find in your Ackerman research, and instead of applying them to an inner and outer tire, apply the diagrams to the inner and outer tire tread. You will find exact same effect on a tire, as you do with the front steering geometry in total.
Also notice that when those diagrams are presented, they are presented at the center line of the tire. The equation would be different if you use the inner line or outer line of the tire.
Try the example of trying to turn a wide tire while rolling it across the floor, compared to a bicycle tire. Then apply that experience to what you're seeing / feeling in real life as you research.
OTOH, maybe the BMW and Audi steering that you've been used to are too numb to feel tires.
You've moved up a notch, as has Mercedes with the V167. Leapfrog.
Old Nov 5, 2022 | 07:12 PM
Frenetic's Avatar
2023 S500
I’m sure the diameter of the tire plays a part of this equation. However, that is a factor I’m sure the MB engineers took into consideration when they designed everything.
Old Nov 5, 2022 | 10:23 PM
Aggie57's Avatar
2021 GLE 350, 2020 911 C2S MT, 2023 Polestar 2, '73 Alfa GTV
Ackermann error.
GLC63 has it bad.
This. Porsche 911’s have done it for decades, we just accept it. Makes zero difference to how the car drives.
Old Nov 5, 2022 | 11:22 PM
Again I am experiencing this same thing from 2009 to 2021 model year and it is ZERO issue what so ever. You are truly experiencing "first world problem" here. Come on man there are other things to worry about like the seat ripping apart or the battery failing but a little slip on the tires on baby crawl speed that does not really affect anything is just being a Karen (no disrespect).
Old Nov 5, 2022 | 11:28 PM
PandaSPUR's Avatar
Subaru BRZ
Jesus man, no car is perfect. If you hate yours so much, just sell it while the mileage is still low and the used market is still hot.
Old Nov 6, 2022 | 12:16 AM
Frenetic's Avatar
2023 S500
I’m not going to sell this thing and take a gigantic loss. I already tried, and even though I put $10k down and paid MSRP, offers aren’t what they used to be a few months ago, coupled with the fact that I got an interest rate below 3%, which i can’t get now.
I’m stuck with this thing for at least a few more years.
Old Nov 6, 2022 | 01:01 AM
mikapen's Avatar
You can fix the crabbing problem the next time you buy tires.
Get the ones with the highest wear ratings, and the lowest traction rating that you can find. That should eliminate the problem, or at least reduce it a lot.
If you really want to have the best outcome for driveways, buy a set of 20 inchers with touring tires that you find in the Used forums. Seriously.
In the meantime, drive the heck out of it. You'll enjoy your car, and you'll hasten the new tires.
Old Nov 6, 2022 | 12:37 PM
Wolfman's Avatar
Super Moderator
This is definitely the same with BMW and others. The more performance oriented the cars are in terms of suspension settings, the more apparent this effect is.
This is very noticeable on our BMW M8 Competition coupe and the car is better for it when driving. Which is when it matters...
Same on our AMG's although it seems more apparent on AWD's.
