GLE 350
GLE 350 4matic
GLE 350
I just bought a 2021 GLE 350 it had 9300 miles when I got it I have notice that the car swing from left to right when I hit som bumps in the Road . Has anyone encountered this problem ?
Does it feel like a sway or shift? My GLE with 22s has that feeling.
Received 1,606 Likes
'21 AMG53 wDPP & ARC, 19 GLC300 - Former- 10&14 ML BlueTecs, 20 GLE450 E-ABC, 15 Cayenne D, 17 Macan
Wider tires are more prone to Tramlining - following depressions in the pavement.
Some brands more than others.
Tire pressure can help, usually.
2023 GLE 450 4matic
36 psi is a bit high if you're not loading the car. My 350 has the 19"run flat tires and i generally keep them around 32 psi. Run flats ride like a dump truck no matter what the air pressure is but above 35, thy start to wander on the road.
19 E63s(wifeys) & a 21 GLE580
Originally Posted by wildta;[url=tel:8751947
8751947[/url]]Does it feel like a sway or shift? My GLE with 22s has that feeling.
I have 20", and didn't have an issue with it, until several months ago when my rear shocks were changed due to a rattle. After that, I started to notice the rear would shift/shimmy after hitting a bump/pothole. I brought it back to MB and was told there was nothing wrong with shocks. However, I did notice that all the tires had since been inflated, by MB, to levels indicated on the door.
Last month, I needed 2 rear tires (yes, I too was shocked after only 22K miles). After that, the ride has been silky smooth, even over bumps. MB also change pressure on all the tires to that on the gas tank. I can only presume it was tire pressure that was causing the issue.
