Dashcam ,how to activate or enable?
Old Apr 8, 2023 | 12:15 PM
nguyensteve's Avatar
GLE53 Coupe
2021 gle53 coupe
How do I activate or enable?
I have memory usb install already
Old Apr 10, 2023 | 10:51 AM
TonyF61's Avatar
2022 GLE 450
I presume that you have this option installed; although, not sure why is shows "deactivated". If so, then it is available under "Mercerdes me and Apps" - see below....
Old Apr 10, 2023 | 11:15 AM
Eaton's Avatar
Top Answer: 1
If you're in the US, it can't be activated.
if you're elsewhere, it can be activated in the Mercedes me Store.
Old Apr 10, 2023 | 12:40 PM
GLE53 Coupe
correct, this is in USA, Florida, so it guess it can not be activated,, wish someone can unlock it for me.
Old Apr 10, 2023 | 12:41 PM
Eaton's Avatar
Top Answer: 1
This is one of those things that is actually impossible, unfortunately.
MBUSA has decided not to offer it on the "older" MBUX cars.
Old Apr 10, 2023 | 01:16 PM
wildta's Avatar
GLE 580
And the aftermarket programmers have told me they are unable to activate it as well.
Old Apr 10, 2023 | 01:36 PM
GLE53 Coupe
thanks group,, so now anyone in the USA have a good source for a dashcam for 2021 gle53 coupe ?
Old Apr 10, 2023 | 01:42 PM
jhoang1990's Avatar
2024 Mercedes Benz GLE350 4MATIC
Is this only for 2021 and older?
I have a 2024 GLE to be built next month and was wondering if the recording will be affected?
I live in Texas.
Old Apr 10, 2023 | 01:48 PM
wildta's Avatar
GLE 580
Vantrue and Viofo both have good reviews.
Old Apr 10, 2023 | 02:53 PM
djgiovanni's Avatar
2021 AMG GLE53 | 2013 SLK350 Sport
Check this out.
I am looking to pull the trigger.
Amazon Amazon
Thank you!
Old Apr 10, 2023 | 04:08 PM
GLE53 Coupe
Originally Posted by djgiovanni
Check this out.
https://www.amazon.com/gp/product/B0...582D5549K&th=1
Thank you!
but we already have a camera there, so what does this product do ?
Old Apr 10, 2023 | 04:14 PM
djgiovanni's Avatar
Not sure I am understanding. If you have the camera there already you should be able to use it. If it is not activated, you'll need to go to the dealership to find out what's goin on. Your car either comes with it ready to go or does not include a dash cam.
The link I sent is for those who do not have the dash cam as optioned (this aftermarket will not work with MBUX).
Old Apr 10, 2023 | 04:17 PM
GLE53 Coupe
if you read up ,, car is in USA and look like M-B USA disable this feature.
Old Apr 10, 2023 | 04:27 PM
Mnewfield's Avatar
2023 e53 AMG
We use BlackVue cameras in our cars and love them.
Old Apr 10, 2023 | 04:31 PM
djgiovanni's Avatar
Yes car is un the USA and in fact in the same city I live in. Why would MBUSA disable your dash cam? Was it done OTA? has your dash cam ever worked?
Old Apr 10, 2023 | 04:49 PM
GLE53 Coupe
Hello ,, i just got the car used so not sure if it ever works, i am checking out all the feature, and see many have dashcam, when to check my and is not enable.
- i did as the dealer if my car have dashcam, and the service lady stated that is not a feature on my car,, but it is clearly there and disable.
Old Apr 10, 2023 | 04:54 PM
djgiovanni's Avatar
Do you actually have a dash cam? Can you confirm you have the hardware? It is located on the plastic cover on the windshield in front of the rearview mirror. If you do, you will be able to see it from the outside. If not, you'll see a plastic cap instead.
Old Apr 10, 2023 | 05:02 PM
Eaton's Avatar
Top Answer: 1
The OEM dashcam is a bonus feature of the AR navigation. It can be optioned at the factory, or purchased later in the Mercedes me Store.
MBUSA opted to discontinue ordering and activation of the dashcam feature due to quality issues with it. The general consensus is that it doesn't work well, and MBUSA was smart enough to realize that. Other countries do still allow activation, however. Additionally, in the USA you can still get the dashcam if the car uses NTG7 (the newer MBUX in the S-Class, C-Class, etc). The NTG7 dashcam works better and is also higher resolution.
It also cannot be activated outside of the Mercedes me Store because it's a special licensed feature, like Trace Pace and Navigation.
Old Apr 10, 2023 | 05:08 PM
GLE53 Coupe
Yes have camera
Old Apr 10, 2023 | 05:40 PM
djgiovanni's Avatar
Discontinued as of when? My previous 2022 GLE 350 had it and worked as it should. How would Mercedes-Benz disable a working apparatus, OTA? If so, with what right would they deactivate something without previous notice to the owner let alone permission?
Old Apr 10, 2023 | 05:45 PM
Eaton's Avatar
Top Answer: 1
To be clear, they discontinued it at the factory level. If you order a new car today, you won't be able to add it to the build.
They won't revoke it if you already have it - no need to worry.
Old Apr 10, 2023 | 05:50 PM
djgiovanni's Avatar
Ok, so going back to the OP inquiry. You have a native dash cam and it is currently not working on your equipped from the factory ‘21 GLE. No reason for it not to be working. Head over to the dealership to have this addressed.
Old Apr 10, 2023 | 05:52 PM
Eaton's Avatar
Top Answer: 1
Based on the screenshot the OP provided, the dashcam feature is not activated, meaning the car was built without the feature.
Old Apr 10, 2023 | 05:55 PM
djgiovanni's Avatar
Interesting… even though he has the camera installed? I wonder if the OP has a non-working AR as well.
Old Apr 10, 2023 | 05:57 PM
Eaton's Avatar
Top Answer: 1
Yup. I don't have a GLE but I am in the same situation. My car was ordered with AR nav, but no dashcam. Since MBUSA decided to not offer it in the store, I can't activate it either.
