Car lurches when moving forward very slowly like in a tight parking situation
I'm experiencing this in my tight garage where I need to park my car at a very specific line otherwise I can't close the garage door in the back and don't have room in the front to walk around the car. While parking in my garage, I'll put my front bumper camera on and inch along until the bumper reaches my specific line, all of a sudden this lurch/forward jerk makes me overshoot it. It's really annoying because I then have to backup.
Last edited by wildta; Jan 28, 2024 at 10:21 AM. Reason: For better clarification of the issue.
Can you see a display that shows your actual gears?
Does your gas pedal move freely?
Parked today with auto start stop off and was able to creep very slowly into my garage at my specific stop line and it worked great so it's definitely an issue with the auto start stop.
If a battery is fully charged, the car will readily shut down, only restarting when low on charge, or the accelerator requests. Sounds like you're there.
Others who "never experience" it might have lower charged batteries that don't let the engine shut down, so no Restart on acceleration.
So maybe both are "normal."
Just thinking out loud.
Update: Engine mounts are fine.
- You're coming to a stop with very light pressure on the brake with the engine running and providing torque
- The car doesn't know whether you intend to stop for a stop light, parking space, or other so it may engage and shut down the engine (no more torque)
- You release the brake to creep forward or backward, now the ISG or starter must refire the engine and immediately begins providing torque while you've released the brake.
- With no brake force the car will jump forward or backward slightly before you re-engage the brake.
All that said, when coming to a stop where start/stop should engage the transition is pretty good. Much more seamless with the ISG than a traditional starter.
The engine shouldn't shut off when you are moving around, unless you're coasting. I doubt that you're coasting into a parking spot.
And the car shouldn't "jump forward" when you release the brake.
Unless I misunderstood your description, it sounds like there's something wrong with your car.
What I do is pushing the throttle ever so slightly and dropping it right away, moving the foot to the brake pedal just in case. Never had to use it but a bit hard to imagine somebody overshooting by a foot, like you have to control how the vehicle moves by being ready to apply the brakes.
