AC odor
thanks!
![](https://staticssl.ibsrv.net/autocomm/Content/MB/mbwambassador2.gif)
Received 3,988 Likes
2017 GLE350 4MATIC
To the top to see if any solutions have been found.
I've used a similar foaming product (2008 BMW that had odor that I couldn't get rid of) that you spray into the system through the duct and it worked perfectly. Only issue was that eventually the audio head died (several years later), and I assumed that some foam might have escape the vent system and eventually caused corrosion. I was never really sure, but that was my guess.
How I finally beat the oder: https://www.amazon.com/dp/B0007PHD0S...roduct_details
Received 1,637 Likes
'21 AMG53 wDPP & ARC, 19 GLC300 - Former- 10&14 ML BlueTecs, 20 GLE450 E-ABC, 15 Cayenne D, 17 Macan
Reading the reviews, this is obviously not a Mercedes unique problem. I wonder if some sort of behavior such as driving in recirculate all the time, or never driving with the windows open and the system off contributes to the problem. Maybe the manufacturers should put a UV light at the evaporator to help kill mold.
Mold in AC is not a Brand thing. It's regional and owner's practice related.
Once it takes residence in your system it's hard to permanently kill it.
#32
UV light is a very good idea. Esp not too big and issue on a luxury vehicle that already has "disco" lighting as a gimmick.
#33
...side note, had to treat my 2020 Raptor for the same problem. Don't remember it being a issue with other vehicles over the last 40 years.
The Raptor I introduced the product through the evap drain. The GLE I went through the center vent.
#34
#35
Will post back when I have to treat again. Has not been a month yet, but still good and both are daily's. Both driven 2 hrs a day M-F, some on weekends.
wildta (09-29-2023)
#36
#37
Drain has a bellowed drain tube from box to body and two 90 degree angles. That had me irritated for a while so removed cabin filter, then cracked door open pushing hose up to condenser (I have inspection camera). Used spray then quickly closed door and let foam work. However drain is recommended and would put you on other side of condenser I believe.
#38
![](https://cimg9.ibsrv.net/gimg/www.mbworld.org-vbulletin/1920x1080/img_2419_3b360d40017134a8c0c24382abd5f69fc9847f70.jpeg)
Turns out the evaporator was clean. The detail guys just used a bunch of fragrance cleaners …. Time for baking soda, charcoal and a steam clean.
I broke out my inspection camera as well.
#39
Unfortunately "clean" may not show the smelly mold or other suspects.
Other strategies are needed, and good luck with yours.
The usual MB haters say that "it's only a Mercedes problem," but they are just chewing cud. Ignore.
Think about it. Would several hundred brands make a line of AC mold busters, if their only market would be Mercedes cars?🤔
If so, why aren't they clearly labeled "for Mercedes?"🤔
Zeusmotorworks (10-15-2023)
#40
Good investigation.
#41
Good investigation.
#42
There is no logical reason to run with recycle on all the time. The GLE is more than capable of adequate cooling without using recycle. I rarely run with recycle on (almost never). I drive with the windows down around town on nice days with the AC off. I live in Florida with a hot, humid environment and have yet to run into this problem. I don't know if constant use of recycled air contributes to the problem, but there does seem to be some correlation with the complaints seen on here.
#43
Has nothing at all to do with cooling.There is no logical reason to run without recycle on 24/7 in the land of "bro" pickups "rolling coal", 1,000 skunks per mile, same for dead deer and other animals on the side of the road, dusty conditions, overpopulation and I could go on and on. You do you and I'll do me.
#44
Noted on the clean but still smelly. I’ll do the baking soda / charcoal thing and an ozone treatment and see where we are. I stuffed my face into the carpet in the back and darn near passed out from the perfume. Turns out they used a fragrance on the carpet and a different one on the all season mats. Uggg… used car detailing.
I’ll hit the evaporator with the foam if any smells persist. I have to rely on my daughter for the smell test as my sniffer isn’t 100%…
so far enjoying the GLE 580. Not as fast as the 605 hp S8 but far more practical.
#45
Enjoy your car. Just wish we didn't have this irritating issue to deal with.
Vandi (10-23-2023)
