coolean tempature gauge
Old Aug 12, 2023 | 09:56 PM
manbeing's Avatar
2023 GLE 450
Is there any way that I could change this part to coolant temperature gauge?
Old Aug 12, 2023 | 10:25 PM
MBguy013's Avatar
Veteran: Marine Corps
2021 GLC 300 4Matic
Would be nice to change it to something else but no.
Old Aug 12, 2023 | 10:44 PM
BlueYonder's Avatar
2024 GLE 450, 2009 SLK 300
Yeah, that is pretty useless information. When I was driving in the Arizona desert last month at 117 degrees, the coolant temp would have been much more valuable information.
Old Aug 13, 2023 | 10:07 AM
jtjbt20x's Avatar
2021 GLE450W4 SUV
No, but it should be there, or in the engine info section.
Old Aug 13, 2023 | 01:50 PM
wildta's Avatar
GLE 580
I guess modern cars just tell you with a warning if your engine is too hot so they got rid of it completely, probably still shows in the service menu though.
Old Aug 14, 2023 | 01:33 PM
mikapen's Avatar
I use the right hand section in the driver's cluster, under the NAV selection, selected via the Home button on the left steering wheel spoke.
It's a tire pressure screen, with engine coolant and tranny fluid displays.
The temps change color as the engine achieves operating temp, and probably change again in an overheat situation.
In my pics here, I haven't driven to get a tire pressure reading yet.
The last pic is with the engine off, showing the display format, but no numbers.
Old Aug 14, 2023 | 05:35 PM
MBguy013's Avatar
2021 GLC 300 4Matic
I think that is only available in the AMG menu options. Don't see it on my 21 450 menu.
Old Aug 14, 2023 | 05:39 PM
wildta's Avatar
GLE 580
@rjautomotive is able to program AMG screens.
Old Aug 14, 2023 | 06:28 PM
mikapen's Avatar
You're probably right.
I wonder if it's hidden under another icon. Can you pull up a continuous display of tire pressures - that might also show coolant temps?
I agree that it's good information to see
Old Aug 14, 2023 | 06:59 PM
MBguy013's Avatar
2021 GLC 300 4Matic
I think the tire pressure is only on the service menu. The coolant temp is on the engine info screen however. Of course, one can always ask RJ automotive to flash the AMG menu options.
Old Aug 14, 2023 | 07:52 PM
mikapen's Avatar
By all means, get the lighting update while you're at it.👍
Add the AMG menus as an add-on.
Old Aug 26, 2023 | 09:11 PM
W205C43PFL's Avatar
Does other displays styles other than classic you have on, like sport, understated, progressive, etc. show it stock instead of having to program it in? or still the same EQ with Power and Charge screen?
The engine data screen in the infotainment show the coolant temperature at all?
Old Aug 26, 2023 | 09:56 PM
MBguy013's Avatar
2021 GLC 300 4Matic
The power and charge is always on as far si know. Then again, I only use the sport display. The coolant temp is on the engine info screen.
Old Aug 27, 2023 | 04:52 AM
Sparky66's Avatar
W167 2021 GLE63S, W223 2022 S580
I think that display is the engine oil temperature and transmission oil temperature. Not the coolant temperature. Had a 450 GLE and on the engine status display it had those plus the battery voltage. On our 63S the engine dispay is not the same as it does not have the battery voltage displayed. Both 2021 models.
Old Aug 27, 2023 | 10:11 AM
W205C43PFL's Avatar
I guess to MB, they think that the coolant usually stays constant (pretty much) once at operating temperature, they don't need to have that information available to the driver. While the engine oil temperature varies, especially on amg vehicles that gets pushed a lot. Regular MB models and customers/drivers perhaps also don't need that information. Just a guess, really.
Old Aug 27, 2023 | 10:13 AM
W205C43PFL's Avatar
I see.
Old Aug 27, 2023 | 01:12 PM
mikapen's Avatar
You are correct, my mistake.
It's oil temp and gearbox temp in those displays I posted.
