Rear camera opens at speed below 25km/h
#51
2023 EQE 500 SUV electric and 2024 Jaguar F-PACE SVR 5.0L
I've been driving a supercharged V8 for the last couple months and I'm pretty sure if my new car made the same noises I wouldn't even notice it. In a silent EV (or maybe even in a fairly quiet hybrid) with sound insulating glass and sound reflecting hard plastics, however... it'll drive ya insane in the membrane. Sound deadening/absorbing interior materials, like the abundant amount of Alcantara in my Jag SVR, would help a lot too I think.
#52
Same problem. Has anyone got solved?
Hello all,
Has anybody had the problem solved?
I’m facing the same problem. The car has been during 4 weeks in the dealer doing several procedures (firmware updates, they checked the wires, tested with new wires connected outside the normal path, changed the module that controls the opening and closed by a new one, they just didn't change the camera itself). In the final, they assumed that they could not fix, and supported with a statement from mercedes telling that's normal.
It’s quite annoying audible sound, every time accelerates or decelerates around 25km/h. The car has just 3 months old, and was not doing it in the first month. By coincidence or not, it started doing after a long trip with a lot of rain and an electrical shutdown problem when arrived from that trip.
I’m wondering if in your case got solved, and the cause, or if you still have the issue after this time.
Thank you for your feedback!
Andre
Andre
#53
Hi Andre! I took mine back to two different dealers and got the exact same result. For now, this is normal unless they come out with a system update. It's the only thing I don't like about this car. Everything else has been great over the first 4 months (first Benz). If anyone hears something different, please share. Thank you!
#54
I'm finding hard to believe that is "fully" normal. My car didn't do it during a couple of months, before started doing it, and I have a colleague who has been the same car for a longer time and has never behaved like this. Seems the car is constantly in calibration mode, and even after having done it successfully and stop with this behavior, it starts doing it again after turn of and on the car. In normal situation it should extend the camera, only when it shows the image (meaning when we put the in reverse gear or something is very close to the car).
Other testimonies will be appreciated!
Thank you,
André
Onlylive1 (01-05-2024)
#55
I’d love to disconnect to motor wires after it’s in the open state, and leave it open. The camera circuit is separate from the 9v motor circuit so I doubt there’d be an error code.
It’s probably wishful thinking and desperation, but I’ve considered it.
#56
Agree
Hi!
Thank you,
André
Thank you,
André
#57
Received 1,582 Likes
'21 AMG53 wDPP & ARC, 19 GLC300 - Former- 10&14 ML BlueTecs, 20 GLE450 E-ABC, 15 Cayenne D, 17 Macan
Does it correspond to the Park icon on the driver's display turning blue? (Indicating that it's looking for a parking spot?)
Can you replicate it by pushing the Park button on the console?
I'm just fishing for connections here. I don't even know what sensors the self park mode uses.
#58
#59
I don't think, it happens in any situation or kind of road. It's the behavior described by Mercedes as camera calibration process. At least in my case, it's not related with self park feature.
#60
#61
How did you find it, and can you provide a link?
#62
I don't think it has anything to do with any of the assist systems. My car has everything enabled and it's not doing it. Basically, the rear camera is only deployed when you can see cameras on the MBUX screen. It's likely something about re-calibration that never finishes or never marks itself as done.
The question I'd ask the dealer is - "why car X is doing it but car Y doesn't". Ask them to grab a car from the lot to compare and persist to get an answer from Mercedes engineers. It's almost impossible to say "it's normal" when you show two different behaviors and ask to explain. In engineering, it's one of the core points we often use to do the troubleshooting. Ability to replicate and compare makes it much easier to debug. That's assuming the telemetry is available. The dealers may not have required skills or level of access but Mercedes engineers should, the challenge is likely to get it escalated to the right people.
#63
Check the attachment from this post: https://mbworld.org/forums/gle43-cou...ml#post7394800
It's pre-v167 but likely applies.
#64
I think I kind of like it, other than the annoying noise part. Seems to keep other drivers from getting too close to my bumper... like the car is going to email the cops that they're following too closely or something. This AI stuff is getting out of hand! LOL
It could just be a coincidence that the camera retracts at exactly the same speed that the blue parking icon for parktronic disappears from my driver info screen. I don't understand why it couldn't do it's calibrating at a higher speed though. The lines on the road are still there.
#65
Hello all,
Andre
Andre
#66
On newer v167, I think 2022+, it's using both ultrasonic sensors AND cameras for parking in marked spaces, it doesn't use the rear camera though.
#67
Dunno about those "hundreds of thousands of people" though.
Have they even sold that many 167 cars into the market?
#68
So, yes, there are "hundreds of thousands" in the US.
#69
According to MBUSA sales reporting, they sold about 250k of GLEs in the US alone (2019-Sep 2023). The reporting doesn't break down by model year, so it's rough calculation just to understand the ballpark, I used 50% of 2019 GLE sales and 100% 2020+ for simplicity.
I guess I'm just too literal. Sorry.
#70
#72
Apparently Parktronic can be temporarily disabled in my EQE. As I was maneuvering around a fast food drive-through this morning (slightly hungover) the ultrasonic sensors started going off and I noticed a red button in the lower corner of the parking camera view on the infotainment screen. Pressing it turned off the incessant beeping. Then as I was going over the train tracks on my way home where the camera typically pops out for no apparent reason, a big white P that said OFF displayed on the bottom of the driver info screen (formerly known as an instrument cluster). Lo and behold, the camera didn't pop out this time.
So I'm 99.9999% sure that's what the problem is... but I expect the authorities in charge who have way more authority than brains will never figure it out and the problem will persist, forever (or until the next gen Mercedes with an Apple-made infotainment system comes out anyways).
#73
GLE
thank you,
Jim
#75
It's not present on all 2024s either, I'd recommend going through this thread, we've probably discussed it multiple times already. There is no solution as nobody knows why it happens on certain cars, it's not normal.
