Gle Coupe Rear Camera Question
I went to the dealer to ask this situation, but they told me it is normal. As I didn't follow other same model car before, so I didn't know if it is normal.
Opening the camera cover for cleaning
To select Open Camera Cover in the 360°
camera menu: turn the controller and press to
confirm.
The Please Wait... message appears for
approximately three seconds.
The camera cover opens.
The camera cover closes automatically if:
the ignition is switched off
the vehicle exceeds a moderate speed
Good luck
but I think it's not normal, and also when I change gear from reverse to drive the camera image on screen stays on till I get higher speed, I will visit the dealer again and ask them to reload the firmware
If I remember correctly, that part is normal. Once the rear camera comes on, if you switch to "Drive", the front camera comes on too until you reach 11 mph. The system assumes you're parking or navigating tight spaces, so it turns on the front camera as well.
It's been my past experience that automakers simply ignore individual complaints like this.....until they get BOMBARDED with them. So everyone with this problem should contact MB Customer Service. Don't waste your time dealing with the dealer. Go over their heads. Dealers only act in response to orders from corporate HQ.
You'll see the same phenomenon at the beginning of these two videos.
When you're in "Park" and then apply the brakes to shift into "Drive", at that moment the door pops open. My theory is that MB intentionally designed it this way to eliminate any delay between switching the camera on and having the image displayed on the screen. When you go from "Park" to "Drive", you're initially at slows speeds. MB assumes you may possibly be maneuvering through a parking lot, garage, etc., so it opens the camera door as a precursor to activating the camera. That's why the door pops open, but you get no image on the screen.
Mystery solved!
You make sense!!! True! Thanks.
I'm not sure why the camera would need to calibrate from time to time though...
