Rear camera pops out at every stop
In the older model years the camera opens when you approach something and the screens show the view from the camera. In the newer model years, the camera opens when you slow down but what for?? You don't see the camera view on the screens anyway.
The only reason I can think of, is that when you punch the camera-view button in the car, it does show the 360deg view, which I assume is only possible if the rear camera is activated.
As opposed to punching the button, and then the lag involved in the camera popping out and activating, before the view comes onto the screen.
Weak excuse I know, but just a thought. Either way, I am a longevity guy (keep my cars for 10+ years, and 200K+ miles), and I personally do not feel this pop-out/pop-in is good for longevity, unless they have specifically engineered/tested it for millions of actuations.
I would like to hear back from Mercedes on the thought process that led them to do this change in how the camera actuates. Let's hear it from the horse's mouth, before speculating.
My 2022 GLE doesn't do this. The camera only pops out when you're close to an obstacle and the 360 view shows up on the screens.
No one seems to know why Mercedes changed the behavior and why the camera needs to pop out if it's not doing anything (showing the view on the screens). This happens on all the newer GLE's as well as other models I've driven as loaners (GLA, GLB).
If I were to guess, by making this change, the Mercedes engineers are solving some - as yet unexplained - deficiency (in the pre-facelift GLEs, like the 2022 GLE referenced above). But they need to explain why this change was made, to prevent further internet speculation (like the highlighted section above).
Incredibly annoying.
https://www.mbscottsdale.com/blog/le...-benz-vehicle/
find a straight road where you’ll have no stops for ~1 minute. Drive forward (and straight <10 degree steering angle) and set your cruise control to 15 mph. I did this, this morning, and it stopped the camera popping out all the time. Supposedly it needs this uninterrupted data to calibrate the camera properly…
here is the fix pdf from an older thread: https://mbworld.org/forums/attachmen...n-3235_001.pdf
If you turn off the car for more than say 15mins it’s back to calibration. In addition this “fix” as per the note doesn’t work in the dark plus needs all the other requirements all lined up ie no car behind, drive straight
In short it’s ridiculous & must be a design failure. Given that this issue has been on posts since 2023 & it’s now 2025. I think MB have no desire to fix it
"So I actually spoke to Mercedes about this as I’ve noticed it too. Previously it was mentioned that it popped out to expose the image ready to show on screen. However I’ve been informed now that all new models may do this and it’s actually part of a calibration process. Now this calibration process isn’t for the camera or camera housing. It’s for some of the safety systems at the rear of the car. Although Mercedes didn’t disclose what safety systems they are, I’m assuming it’s “Drive Away Assist” or Crossing traffic” or maybe “Active Blind Spot Assist” calibration."
So I fail to see how this can be a safety system. Sure if the camera was always out & somehow monitoring “cross traffic” or helping with “blind spot monitoring” etc however as I say if the camera does calibrate. It ain’t coming out again unless you choose reverse or park. So at junctions when stationary it’s not dropped down.
If it was for safely then surely it wouldn’t disappear.
What's weird is that it would eventually stop doing it during the day but it was constant at night. I assume it eventually calibrated itself during the day but this is simply ridiculous. There's got to be a better way. I noticed the camera going in and out correlated with the car scanning for parking spots so I thought it was related to that system, even if my own car didn't exhibit the same behavior.
As I've stated in the past, MB builds a great car but their software people leave a lot to be desired.
