Rear camera pops out at every stop
Old Apr 30, 2025 | 03:00 PM
  #201
W205C43PFL's Avatar
Originally Posted by mikapen
I think I'll keep my '21 longer than usual.....
Think that is not a bad idea. You also don't have to deal with or (get used to) the capacitive touch of the facelift.
Old Apr 30, 2025 | 03:10 PM
  #202
jaxslk's Avatar
2025 GLE 450, 2022 AMG GLE 53
Such a strange issue that defies figuring out the root cause. Our 2025 GLE450 does not have the problem, and it has the Driver Assistance package. Software is RL_NTG7_E504.304_24133AC3
Old Apr 30, 2025 | 03:18 PM
  #203
W205C43PFL's Avatar
Perhaps they fixed it or the issue started on E505? Yours just behind it. Unless this is a batch hardware defect issue?
Old Apr 30, 2025 | 03:22 PM
  #204
mikapen's Avatar
AND my MBUX is more customizable, my camera doesn't pop out, it has AMG ARC, Track Pace, no rattles at 45,000 miles, and.....
Old Apr 30, 2025 | 03:43 PM
  #205
arnautovica's Avatar
2025 GLE 450 Coupe
My software is 505 and have no problems (knock on wood)
Old May 1, 2025 | 06:16 AM
  #206
W205C43PFL's Avatar
Old May 1, 2025 | 06:17 AM
  #207
W205C43PFL's Avatar
Interesting, um the mystery continues.
Old May 1, 2025 | 01:33 PM
  #208
Lucky 777's Avatar
Top Answer: 1
2024 GLE 450 4matic
I hate the capacitive touch controls on the steering wheel!
Old May 1, 2025 | 01:39 PM
  #209
W205C43PFL's Avatar
Sadly, it doesn't seem to be going away, at least the good thing is MB is bringing some physical buttons back, first seen in the W223 facelift spyshots.
Old Nov 11, 2025 | 08:45 AM
  #210
lmc2's Avatar
99ML320, 05BMW325xi, 20BMW228ix, 25GLE450
One more unhappy camper here! My 2025 GLE 450 has the Driver Assistance package. Software is RL_NTG7_E505.404_24441AC3. The rear camera is poping in & out at low speed.
Did anyone file for safety complain on NHTSA.gov web site yet? Maybe start a class action lawsuit if any lawyer reading this thread interested!
Old Nov 11, 2025 | 09:33 AM
  #211
Elvisfan0108's Avatar
2021 c300 Cab. Arrived 7/28/21 . 24 GLE 450e.
Where is the safety issue? Class action suit for what?
Old Nov 11, 2025 | 09:37 PM
  #212
mikapen's Avatar
To those of you who have this rear camera popping out issue, have you gone into the menu and disabled the "warn early all around" setting?
It's probably not the solution, but it's worth checking.
Old Nov 12, 2025 | 02:58 PM
  #213
stevieg58's Avatar
w164, v167
I have been suffering from and following this issue for roughly the past year. Along with this post, I have followed similar postings on other sites (such as https://www.mercedesgleforum.com/thr...?nested_view=1 and https://www.mercedesgleforum.com/thr...-gle-350.4438/). Many have reported brief relief from software updates to the park control unit, but no definitive fixes yet that I have seen. I assume many are aware that Mercedes has a couple of sound proofing blocks (parts 166-682-03-41 and 166-682-00-70), but most people say are only minimally effective.
However in the second link I posted above, I was excited to see post #10 where bkp says he "found a solution if you're willing to pay for it." His solution was to put Siless Max sound deadener all around the rear hatch camera area. The success was confirmed on post #33 by JRD47. That was enough evidence for me to order the Siless Max from Amazon and make plans to install it. I am also calling it a great SUCCESS. Not silent, but probably 95% improved. What a relief! Details below.
Amazon sells the Siless Max either as 6 square feet, or 30 square feet.
Amazon Amazon
I got the 30 square foot box, but only used about a third of it. However, not sure 6 square feet would have been enough. Perhaps two of the 6 square feet boxes is the sweet spot.
This is the best how to I could find for removing the rear hatch trim:
Obviously a different model than the v167, but (other than two handles vs one) it is very similar to my 450e. Be sure to note the metal clips inside the handle grip that he shows at around 45 seconds in the video. It is essential that these clips be removed, and it's probably the hardest part of getting the trim off. One would think that all you need to do is squeeze them and they should slide right out, but there is secondary ridge of metal behind the outer edge of the clip - and both sides of this ridge need to be pressed in at the same time before the clip comes out. I ended using a combination of a very thin small screwdriver and a pick. Frustrating, but keep at it and you'll get it. You'll also want a nice pick tool to undo the electrical connections as seen in the video. Also, I wouldn't use the handle as the method for initially separating the trim from the plastic clips like he does in the video - when I did that the handle separated from the trim piece. It clipped back in just fine, but a little unnerving when it happened. My advice is to work the edge of the trim piece with a plastic pry tool until a plastic clip loosens.
For the other plastic clips I recommend having an extra long clip removal tool (such as
Amazon Amazon
I was very careful and all my plastic clips came out without losing or breaking any, but you might want to have some spare ones hand in case any break during removal. Part # 001-991-32-98.
After removing the trim, this is what the back of the hatch looks like. Two layers of sheet metal seemingly designed to echo the clicking noise of the camera opening and closing.
I particularly focused on attaching the Siless around the area under the rear wiper where the camera is located. I really went to town on it and put lots of small pieces everywhere I could think of - basically filled that area up. The Siless cuts easily with a large pair of bandage shears. As can be seen, there are two pieces of sheet metal that form the rear hatch. Attempting to dampen any reverberation that may be occurring between those two areas I put several sheets of Siless on both sides of the internal cavity. Then I also covered all the openings. Of course, note where the clips fasten to the hatch and leave those areas uncovered. This is how it looked when I was done:
As an aside, even though I mentioned the sound blocking parts that Mercedes offers, I did not use them since so many people have said they are only minimally effective.
Quite a shame that I had to pay for the solution myself, as well as spend about an hour cutting and sticking on the Siless, but I am very, very pleased with the outcome.
Hope that helps.
Stephen
Old Nov 12, 2025 | 07:32 PM
  #214
I’m glad that this is solving your “problems “.
Old Nov 15, 2025 | 01:17 PM
  #215
mcb's Avatar
mcb
C200 Estate (S206)
Hello there,
I have the same issue with my C200 Estate with NTG7_E329.501_22411AC3. I am gonna visit the dealer in two weeks and will update the MBUX. I unfortunately got the static noise issue once, too. I hope the update could solve both. I will file a claim to MB HQ since I do believe that it is a very stupid thing we are having. Before this car I had an E Class W213 with 360 degree camera and I didn’t have this issue at all. Why I am having this I really don’t want to understand, but it annoys me a lot.
Old Nov 16, 2025 | 07:13 AM
  #216
lmc2's Avatar
My brother-in-law has a '25 GLC320 and confirmed that he has the same issue of the rear camera poping in and out at low speed.
I was behind a GLE320 and 450 yesterday stopped at the traffic light. The rear camera of the 320 (probably '24) didnt pop out but the 450 (exactly the same as my '25) poping out when it slows down.
Old Nov 16, 2025 | 07:24 AM
  #217
lmc2's Avatar
I couldnt find this option on my '25 GLE450 but tried every option with no luck. Note that the MBUX changed a bit from year to year and also depends on the options equipped.
Anyway, I am going to bring it to the dealer to check a couple of things. Mostly annoying bad design and cauing distraction while driving, which i consider safety issues using Mercedes high standard. If it is a Hyundai, I would say you get what you paid for.
Old Nov 20, 2025 | 12:59 PM
  #218
pjw1967's Avatar
2023 GLE3502W, 2024 GLC3002W, 1967 Pontiac GTO 4 sp (sold...sniff)
Many GLC owners, Including me, have the same problem. Dealer was no help. I think it is looking for parking spots below a certain speed.
Old Nov 20, 2025 | 02:52 PM
  #219
Since the blue P shows up at the same time, that would be a good guess. I agree that it makes no sense but, at the same time some of the comments on here appear to be a bit much. A safety issue?
Old Jan 30, 2026 | 04:53 PM
  #220
DHCMB's Avatar
S550, SL550, GLE450
Amazon Amazon
Amazon Amazon
Hope that helps.
Stephen
stevieg58,
Thank you very much for your post! I bought Siless Max from Amazon and installed it this afternoon. I am back from my first drive after installation and the Siless Max made a huge difference. I also purchased some batting at a fabric store and stuffed it into all cavities in the tailgate during the process. I have struggled with the camera since we have owned the car and have been extremely disappointed in the way MB has ignored this issue. The treatment they have given their customers has been atrocious. I have been a loyal MB customer for over 40 years, but I will be looking elsewhere the next time I am in the market.
Bottom line, with the radio on, I cannot hear the camera.
All, if you have struggled with this issues, here is your fix. I am extremely happy with results.
Again, stevieg58, much appreciated.
Doug
S550
SL550
GLE450
Old Jan 30, 2026 | 08:29 PM
  #221
Originally Posted by DHCMB
stevieg58,
Doug
S550
SL550
GLE450
I really can’t believe this bothered people that much. Enough to take the back of the hatch apart. If the camera stopped working, that would bother me. I guess I’m too old to complain about a MINOR noise issue. There are bigger fish to fry. Like some of the following posts.
Old Jan 31, 2026 | 04:06 PM
  #222
mikapen's Avatar
My '21 doesn't do that, and after seeing all these posts about it, I thought that it must be horrible.
I'm very sensitive to noise and rattles - I can hear my wheel locks rattle in their plastic box in the spare tire well. The box is stuffed with cotton gloves to de-rattle.
You should see what I did to my old Land Cruiser FJ-45 for noise reduction!
Then I had a A Class loaner whose camera popped out every time I slowed. It didn't bother me one bit.
Old Jan 31, 2026 | 05:57 PM
  #223
2025GLE's Avatar
It is the most annoying noise I have ever had in an automobile. the Siless worked.
Old Feb 3, 2026 | 08:39 AM
  #224
Typical Guest's Avatar
2023 EQE 350+ SUV
Hi, I have the 2023 EQE SUV 350+ with the same Camera Popping issue. My 2023 EQB did this only when a Truck or Car was a bit close to my Car in a Traffic situation, but not as often and unprovoked as it does now on the EQE.
After over 220 Posts to this Topic in here One might think MB is taking Notice, but this is a dark corner of the Internet.
I bet you, if a Youtuber with a big audience in the US or Europe would post this, it might get an over the air update quite quickly. I can see this happening here in the US with the Out of Spec Channels from Kyle Conner and his Team or others in Germany like the Carmaniac Channel. It seams they even work with the Software developers from manufacturers to kind of field testing the Cars for free for them.
Someone should point them to these Forums here or elsewhere to find Topics to create Content for their Channels and find Problems Consumers have with their Cars.
Old Feb 3, 2026 | 11:42 AM
  #225
unrecognized88's Avatar
2024 GLE450, 1998 LEXUS GS400
I found this from the FB groups. An MB tech said that this is what they did to drastically reduce the sound from the rear camera. I had my dealership do this and it worked. I'll obviously still hear it when the volume is completely off, but it's much improved and during regular driving, I don't hear anything anymore. It used to sound like something was rolling around back in the cargo.
XENTRY PORTAL > Startek NG > Passenger > Driver assistance > Rear Camera Door Noise Reduction Technique
Currently Active Users Viewing This Thread: 5 (0 members and 5 guests)
