I have read lots of posts here, so is the 48V battery covered by the 8yrs/80,000 ?
Old Jan 6, 2024 | 01:28 PM
manbeing's Avatar
2023 GLE 450
Is the 48V battery covered by the emission 8yrs/80,000 miles warranty?
Old Jan 6, 2024 | 05:56 PM
TexAg91's Avatar
2020 Mercedes GLE350 4Matic; 2023 Tesla Model Y
yes
Old Jan 8, 2024 | 06:56 AM
Pappa's Avatar
2022 GLE 350
Originally Posted by TexAg91
yes
I just read in the “Just realized MB extended warranty doesn't cover struts” posting that MB do not cover batteries.
Old Jan 8, 2024 | 12:38 PM
Was Ferrari Guy's Avatar
Top Answer: 1
2021 53 AMG SUV, 2021 GMC Denali, 2015 Bentley Speed convertable
I have been hearing both yes and no answers to the battery question. Anybody have something in writing? I have a 2021 53AMG and I am not going to buy a new one until a major change in the model, so I am starting to be concerned about the battery warranty.
Old Jan 8, 2024 | 01:57 PM
mikapen's Avatar
If I have found the correct battery, OE replacement costs about $1300.
I can handle that.
https://www.mbpartscenter.com/oem-pa...xlY3RyaWMtZ2Fz
Old Jan 8, 2024 | 03:34 PM
stktyz33's Avatar
MY2024 GLE 450
No need to guess, check the service manual. Here is the link for 2024 GLE SUV in the US: https://www.mbusa.com/content/dam/mb...ty-booklet.pdf
Search for "48V Battery". It appears to be NOT covered under federal 8/80 emission as it doesn't have that asterisk "*", see the fine print. It is covered by CA 7/70 (CA, CO, CT, DE, MA, MD, ME, NJ, NY, NY, OR, PA, RI, VT and WA Only)
Old Jan 8, 2024 | 04:24 PM
stktyz33's Avatar
MY2024 GLE 450
Amended my earlier statement as I found the fine print for federal 8/80.
Old Jan 8, 2024 | 06:05 PM
TexAg91's Avatar
That is correct Mercedes-Benz does not cover the 48 V hybrid battery under the new car warranty. It is covered under the emissions warranty, which is a separate warranty.
The new car warranty, and extended warranty are separate warranties from the emissions warranty. The emissions warranty is federally, mandated and electric components are included because manufacturers use them reduce emissions.
That said this applies in the United States.
Old Jan 8, 2024 | 06:10 PM
stktyz33's Avatar
MY2024 GLE 450
If you check my post above, it doesn't look like 48V Battery is covered under federal 8/80. Only by CA (+some other states) for 7/70 if you fail the test. The federal list of federal specified major components is super small and covers just a few components: https://nepis.epa.gov/Exe/ZyPDF.cgi?Dockey=P100NNQH.pdf . These components (Catalytic converter, ECU, No OBD but the Instrument panel) are also marked by "*" in the service manual
Old Jan 8, 2024 | 09:37 PM
TexAg91's Avatar
See (3) on page 29, then refer to page 51.
Old Jan 8, 2024 | 09:46 PM
stktyz33's Avatar
MY2024 GLE 450
We are looking at the same page but reading it differently. The notes on page 51 clearly say that items marked with the asterisk (*) have 8/80. The items marked match the federal list that only has three items. The other item fall under “a” or “b”.
happy to be wrong here.
Old Jan 8, 2024 | 11:01 PM
TexAg91's Avatar
[QUOTE=stktyz33;8904941]We are looking at the same page but reading it differently. The notes on page 51 clearly say that items marked with the asterisk (*) have 8/80. The items marked match the federal list that only has three items. The other item fall under “a” or “b”.
happy to be wrong here.[/QUOTE
I see your point — that appears to be a change from
prior model years. Unfortunately I think you are interpreting that correctly on the 2024 GLE with the 48v battery.
Need to look at the specific warranty by model year to be sure.
Old Jan 9, 2024 | 12:49 AM
Pappa's Avatar
2022 GLE 350
I’m reading the same. You are correct.
Old Jan 9, 2024 | 01:03 AM
roadtalontsi's Avatar
10 C six trizzle
You posted it's $1300.... , That's if you buy it and replace it yourself. The dealership will likely add an addition 15% above list because that is what they do. In addition to that labor at $220+ /hr. Will definitely require a teach in procedure. So easily looking at a $2500-3000 cost.
Old Jan 9, 2024 | 12:30 PM
Top Answer: 1
I can live with a cost of $3,000 but I really hope the GLE does a major change and not a little face-lift soon. I would love to buy a new GLE that is a major change.
Old Jan 9, 2024 | 12:48 PM
wildta's Avatar
GLE 580
v168 should be around 2027-28. After seeing the other models' new interiors, I'm not too excited about the interior changes that might be coming into the v168. I'm hoping 🤞🏽 they are listening to user feedback.
I agree the $3k isn't that much of a hit and likely cheaper with an Indie.
Old Jan 9, 2024 | 01:14 PM
stktyz33's Avatar
MY2024 GLE 450
It's not a radical change but the facelift is quite different, electronically (NTG7 and other HW updates, Burmester updates for Dolby Atmos / Personalization etc) and mechanically (ISG v2 that moved it to the transmission). For 350s, they got 48V too (likely for waiting for ISG v2), making the entire range electrified. While it may not be enough for your needs but I found that many people don't realize that 2020-2023 and 2024 are not the same. Earlier years also have differences but a bit more subtle.
Old Jan 9, 2024 | 01:50 PM
jkaetz's Avatar
2021 GLS580 | 2011 ML350 BlueTec | 2009 Pontiac G8 GXP
I was able to find 2020, 2023, and 2024. None appear to cover the 48v battery beyond the 3/50 or 2/24 timeframe. After two years in most states and three years in all others you're on your own for replacement.
2020: https://www.mbusa.com/content/dam/mb...e_Warranty.pdf
2023: https://www.mbusa.com/content/dam/mb...ty-booklet.pdf
2024: https://www.mbusa.com/content/dam/mb...ty-booklet.pdf
Old Jan 9, 2024 | 02:08 PM
stktyz33's Avatar
MY2024 GLE 450
It does have 7/70 48V battery coverage for CA, CO, CT, DE, MA, MD, ME, NJ, NY, OR, PA, RI, VT and WA under "CA Emission defect". It does say you can present a claim right "after failed smog test" in 1 place out of 3 (the other 2 have no mention of the smog test requirement) that refers to this warranty. It's not clear if failing the smog test is required in practice or if the car fails it when 48V Battery dies. Does the test fail when you can't start the car?
Old Jan 10, 2024 | 02:40 PM
cypress822's Avatar
GLE 450
2021 GLE 450 42K miles. (Bought it brand new in 2021.)
I asked dealer for extended warranty a few weeks ago--quoted me $7700!!
Is this typical? Wow!
Old Jan 10, 2024 | 03:05 PM
Pappa's Avatar
2022 GLE 350
Nope!
I asked a dealer for extended warranty a few weeks ago--quoted me $7700!!
. Fact is, I learned to only lease a Mercedes. The cost of ownership is not worth the trouble. In addition, many of the electronics, batteries, struts, etc., are not included in the extended warrenty. A car, unlike family, you don’t have to keep them. Going further, Mercedes is not your family, much less your friend. They only want your money. So, just lease the car and walk away from it after the lease ends.
Old Jan 10, 2024 | 03:55 PM
wildta's Avatar
GLE 580
Search for Jeff Jackson (Louisville MB) on here. He's well known and will give you a much better price.
Old Jan 11, 2024 | 11:26 AM
mikapen's Avatar
Impossible to say without knowing your mileage, the length of the coverage, and which "warranty" (or breakdown insurance) you are shopping for.
Old Jan 8, 2025 | 05:27 PM
Tbrown87's Avatar
2019 Convertible AMG E53
48V Battery warranty coverage
I received a 48V battery check engine light and am currently disputing the dealership's decision that it’s not covered under warranty. I contacted MBUSA corporate customer service, and the case has been escalated to a case manager. The issue lies in a discrepancy: the dealership's system indicates the 48V battery is not covered, while the MBUSA warranty booklet clearly states it is. I sought help from the corporate team to resolve this contradiction, but unfortunately, the escalation process will take at least three business days. I’ll keep you updated as I receive more information.
Old Jan 8, 2025 | 05:29 PM
wildta's Avatar
GLE 580
What state are you located in?
