GLE350DE, diesel engine starts shortly every time I turn on the car
Old Feb 4, 2024 | 03:18 AM
tobiasbl's Avatar
GLE350DE -21
Hello all,
I recently leased a GLE 350 DE 2021. plug-in hybrid.
And I'm a little annoyed that the diesel engine starts shortly every time I turn on the car, even with full battery (engine turns off after like 20 seconds..), is this something that could configured to avoid?
best regards Tobias
Old Feb 5, 2024 | 02:21 AM
elbekko's Avatar
'22 GLE 350e
How cold is it, and what temperature do you have the heater set at?
Try leaving it plugged in and using the pre-heat function. Then it's up to -10°C or so before the engine kicks on in my experience.
Old Feb 5, 2024 | 03:52 AM
tobiasbl's Avatar
GLE350DE -21
Thank you for your answer,.
It have been with batterylevels between 50 and 100 %, and been in warm garage (+15 degrees..), it starts the diesel engine. I can add that the vehicle have Airmatic if that should make any difference?
regards Tobias
Old Feb 5, 2024 | 03:54 AM
elbekko's Avatar
'22 GLE 350e
The warm garage is surprising, 15°C+ shouldn't trigger the engine starting. Airmatic shouldn't make a difference there, mine has that as well.
Is this in EL or C mode?
Old Feb 5, 2024 | 04:02 AM
tobiasbl's Avatar
GLE350DE -21
I'm very new to the car, but as I understand it starts in C, don't know how to force it to start in EL automatic? Which mode does your start in?
regards Tobias
Old Feb 5, 2024 | 04:05 AM
elbekko's Avatar
'22 GLE 350e
If you had it in EL, it'll restart in EL again (at least, mine does). Most other modes will default back to C (eco might not, but I never use it).
I would expect it to not start the engine at those temperatures if you parked it in EL.
Old Feb 5, 2024 | 04:07 AM
tobiasbl's Avatar
GLE350DE -21
Thanks. I'll try this next time I'm driving the car! regards
Old Feb 9, 2024 | 04:32 PM
tobiasbl's Avatar
GLE350DE -21
After driving the car in sport mode for about 15 km, it have stopped staring the diesel every time I start the car in comfort mode or EL mode. Seems like the dieselengine havenät been running much lately and that
s the cause for this strange behavior, probably to remind the driver to run the diesel engine properly from time to time
And that
s what Mercedes said when I asked them about this the other day.
regards Tobias
