Has Anyone Tried a USB C Hub
Old May 15, 2024 | 04:04 PM
bkushner's Avatar
2024 GLE 580
Has anyone tried using a USB Hub to add addition ports in their car? Would it work?
Old May 15, 2024 | 04:58 PM
superswiss's Avatar
2019 C63CS
No, as far as I know it doesn't work. Hubs are not supported. If you plug it in you'll get an error message in MBUX from what I've seen stating that hub devices are not supported.
Old May 15, 2024 | 05:40 PM
FireRx Captain's Avatar
2020 GLE 350 4Matic, 2016 E350
I would imagine its a power output thing. a hub would have to have it's own power source.
Old May 15, 2024 | 10:28 PM
kauffee's Avatar
GLE 450e, EQS SUV
I have a dual-port fast charger that plugs into the 12V outlet. When I need to charge my phone fast it works well. Not sure if you can attach a hub to it, but maybe.
Old May 15, 2024 | 10:47 PM
bkushner's Avatar
2024 GLE 580
yeah, this is what I did. I had a 12 V that had three or four ports on it. But the new 24 or at least the one I have got rid of the 12 V socket in the front. Just have the two USB ports.
Old May 15, 2024 | 10:56 PM
kauffee's Avatar
GLE 450e, EQS SUV
That's weird. My '24 450e has the 12V right next to the 2 USB ports in the front.
Old May 15, 2024 | 11:01 PM
bkushner's Avatar
2024 GLE 580
Yeah I have a 580 and also a had an amg53 both built in April. They did away with that set up.
Old May 16, 2024 | 06:23 AM
EndenDragon's Avatar
2024 GLE 450​
Hmm I wonder if it's because it's not the pinnacle trim (or some other package) given that the cup holders don't have the hot cool buttons?
Old May 16, 2024 | 09:38 AM
streborx's Avatar
Top Answer: 1
G550
If all you're trying to do is have additional charging ports, buy a USB-C power splitter.
Amazon Amazon
Old May 16, 2024 | 11:50 AM
superswiss's Avatar
2019 C63CS
If you have the wireless charger, then there's no 12V socket anymore. Not sure about the GLE, but I have a 12V socket below the glove compartment in my '19 C63S coupe. They relocated it with the addition of the wireless charger.
Old May 16, 2024 | 02:29 PM
jkaetz's Avatar
2021 GLS580 | 2011 ML350 BlueTec | 2009 Pontiac G8 GXP
While it is possible to "split" power from a USB PD output, it isn't a common functionality. USB PD isn't simply a power source like the old 12v sockets. It negotiates with the device and cable connected to it on what voltage (5v, 9v, 12v, 15v, 20v) and amperage (<=3 A, <=5 A) to provide. It's entirely designed around the idea of one port/device. That said, it is possible to get a USB PD trigger that will negotiate a specific voltage with the PD host and then any device can be wired to that trigger to use the negotiated output.
What is the goal? More charge ports?
