Hesitant to turn over / start
Old May 27, 2024 | 08:09 AM
Marmalade's Avatar
Mercedes GLE350
I’ve noticed that putting my foot on the brake and pressing the start button occasionally won’t start the car.
Then I’ll try again. Then I’ll turn it off, open the door, close the door and try again.
This usually works. But last night it took five tries.
Mostly it’s fine. But the reluctance is becoming both more common and now much longer.
Thoughts?
Old May 27, 2024 | 08:27 AM
streborx's Avatar
Top Answer: 1
G550
How old is your battery?
Old May 27, 2024 | 11:16 AM
Marmalade's Avatar
Mercedes GLE350
12 months?
battery was replaced last year under warranty
Old May 27, 2024 | 11:46 AM
streborx's Avatar
Top Answer: 1
G550
Any difference if you press harder or wiggle the brake pedal? When the car does crank, does it turn over normally and start right away, or is the crank sluggish?
Old May 27, 2024 | 01:38 PM
Marmalade's Avatar
Mercedes GLE350
it doesn’t try to turn over at all. It’s not weak, it just doesn’t start to start.
Old May 27, 2024 | 03:37 PM
mikapen's Avatar
Try a fresh battery in your key.
Also, what year is your car? On older models you can remove the button and use the key directly instead. If so, try that.
Old May 27, 2024 | 04:39 PM
jkaetz's Avatar
2021 GLS580 | 2011 ML350 BlueTec | 2009 Pontiac G8 GXP
Would likely need a diagnostic tool that would show realtime data to see where the problem is. Something between your button and the starter is obviously not happy if you don't get any action, sounds, or messages.
Old May 27, 2024 | 09:31 PM
Marmalade's Avatar
Mercedes GLE350
I’ll try a fresh battery. Good idea.
