Lowering Vehicle for Entry
Old Aug 13, 2024 | 05:04 AM
bkushner's Avatar
2024 GLE 580
Is there a way to lower my 2024 GLE 580 for entry and exit?
Old Aug 13, 2024 | 10:39 AM
BlueYonder's Avatar
2024 GLE 450, 2009 SLK 300
With the engine running, select the function button (looks like a car) on the center console. The menu on the screen will have a lower option displayed.
Old Aug 13, 2024 | 12:09 PM
bkushner's Avatar
2024 GLE 580
that button allows me to raise car only.
Old Aug 13, 2024 | 12:21 PM
Eurocar11's Avatar
2024 GLE450 & 2022 CLS450
You can engage the "lower" function while stopped with the engine running or in motion....provided you do not exceed 19 mph.
However, it seems you have to select "lower" each and every time you drive the car. At least on the 2024's, there doesn't appear to be a way to select it once and have it stay in "memory."
Old Aug 13, 2024 | 12:23 PM
wildta's Avatar
GLE 580
Not sure about speed threshold but pre-facelift also required pushing the button with each drive. No memory save but I wonder if @BenzNinja can program it to lower each time you park?
Old Aug 13, 2024 | 12:27 PM
BlueYonder's Avatar
This button (9) brings up a lower option on my right screen. Engine must be running to activate it. It will continue to lower the car after the engine is shut down. The lowering pauses if the door is opened.
Old Aug 13, 2024 | 01:30 PM
bkushner's Avatar
2024 GLE 580
OK thanks everyone.
Old Aug 13, 2024 | 04:31 PM
mikapen's Avatar
I just go to ,Sport mode. It achieves the same thing and there's less fuss.
Old Aug 14, 2024 | 11:17 AM
GregW / Oregon's Avatar
2020 GLE 450; 2023 BMW M2 Coupe
Lowering
The Entry/Exit function s at Sport+ level, -1.0", whereas Sport is -0.6".
Old Aug 14, 2024 | 11:47 AM
zengshengliu's Avatar
2020 Mercedes GLE 450
Does it stay low when you go back to the car?
I always use the lowering function for that, and I found that if I put the car in lowering mode while car is moving (close to destination, turn on lowering), and park only after the car is completely lowered, then most of the time it will stay at the lowered position when I come back to the car.
But if I lower the car after parked, or enter park while lowering, most of the time, the car will be at the normal height when I come back.
Wasn't sure the behavior for the sport/sport+ mode.
Old Aug 14, 2024 | 07:26 PM
mikapen's Avatar
That be true for standard air,.
I forgot that my AMG53 is one step lower. My Sport and Sport+ are the same.
Old Aug 15, 2024 | 05:06 PM
jonpom's Avatar
08 GLK350, 10 E350, 12 R350, 14 CLA250, 18 E400 Coupe, 20 GLE580, 21 GLC43, 21 GLC300, 24 GLE53 SUV
What does “one step lower” mean? I can find no reference to actual measurements in the AMG manual. Only refers to “lowest level” for both Sport and Sport+.
Old Aug 16, 2024 | 01:32 PM
mikapen's Avatar
I don't know the exact measurements either, but, in essence, my comfort mode is the same height as sport in others.
My Sport goes down one notch, and Sport+ doesn't drop further.
Old Aug 16, 2024 | 04:13 PM
stktyz33's Avatar
MY2024 GLE 450
For non-amg vehicles:
Old Aug 16, 2024 | 05:03 PM
jonpom's Avatar
Wonder why MB is so specific re non-AMG while very vague re AMG.
Old Aug 16, 2024 | 10:48 PM
Ron.s's Avatar
2024 GMC Canyon Denali..... 2018 Audi SQ5
Going from memory...measured my 2021 GLE53 at about .5" or .6". Just used a tape so a rough number.
I might be confusing my earlier 450 but at highway speed in C mode one or both lowered about the same amount! The amount it lowered and at what speed are listed in the Owners Manual. For an approximate, try measuring the drop near the center of the vehicle.
Old Aug 16, 2024 | 10:55 PM
stktyz33's Avatar
MY2024 GLE 450
I posted some rough measurements here: https://mbworld.org/forums/gle-class...ml#post8891240
Old Aug 17, 2024 | 01:41 PM
Same as I posted above in #11.
Old Oct 7, 2024 | 12:57 PM
jonpom's Avatar
I never noticed this tidbit before:
“If the entry / exit level function is activated, the vehicle is set to the Sport + level to facilitate entering/ exiting the vehicle.”
so this “easy entry / exit function” not only moves seat and steering wheel but lowers car as well!
Old Oct 7, 2024 | 01:11 PM
mikapen's Avatar
They are separate functions.
Old Oct 7, 2024 | 03:22 PM
jonpom's Avatar
So, 2 separate functions with the same name?
Old Oct 7, 2024 | 05:43 PM
mikapen's Avatar
My apologies. I just realized this thread was about post facelift cars.
I was talking about my 21 which does have two separate functions, as you see from the attached pics.
Probably won't be the last time compare my Pre-facelift car to Post-facelift.
"Lower when getting in" has always been a source of confusion for me anyway. Either it's inconsistent, or I am. Sometimes it lowers on getting out and raises for getting in, and sometimes it stays lowered.
An earlier post about opening the door's interrupting the lowering cycle might be my my error.
