AMG GLE 53 Center Caps
Old Mar 10, 2025 | 10:14 PM
billjo's Avatar
GLE 350
The other day I was stopped at the store and noticed that my center cap on my front wheel was missing. Upon closer inspection I figured out that someone had used something to pry against the wheel to pop/break the cap off.
Fast forward I've been trying to find a replacement and it's not as easy as it sounds. My 1st call was to Mercedes and was told I needed to buy a set of 4 so I turned to Ebay to buy one. I ordered the one that was said to fit which was part #00040042009283 and when it arrived the center was different. Keep in mind you supposedly buy the centercap separately, then I ordered the set from MB and when they arrived it didn't have the correct cap. Went to the MB dealership and they checked and confirmed it was the right number(via VIN), I had my original with me minus the cap that has a part # was different but they couldn't find anything in the system to match it. After 30 minutes they said mine must have been from another car, I bought the car new so I doubted that. Then we went onto the lot and they had a 53 & 63 that had caps that matched mine, so back inside to search the part number via those VIN numbers and still not the correct center.
I've ordered 2 others from the internet and none have matching caps, any idea how I can find the correct cap?
Old Mar 14, 2025 | 08:43 AM
miszaa's Avatar
W204 C300, GLE V167 450
Hi,
Try check with
Kunzmann Onlineshop or Mercteil
Old Mar 14, 2025 | 12:35 PM
mikapen's Avatar
I'm not sure what I'm looking at here.
Do you have center locks?
Old Mar 15, 2025 | 06:04 PM
billjo's Avatar
GLE 350
The center "cap" threads in to hold the "saucer" in place to hide the lugnuts.
Old Mar 15, 2025 | 06:15 PM
BlueYonder's Avatar
2024 GLE 450, 2009 SLK 300
Are you sure that "this" piece doesn't have to be removed first?
Old Mar 15, 2025 | 06:17 PM
billjo's Avatar
GLE 350
I'm not trying to remove it, I'm trying to find the part number to the one that matches my original, the one the arrow points to. The one in my hand isn't the same and I've bought 7 so far trying to get the correct one.
Old Mar 15, 2025 | 06:48 PM
GregW / Oregon's Avatar
2020 GLE 450; 2023 BMW M2 Coupe
Show a full pic of the wheel.
Old Mar 15, 2025 | 07:03 PM
billjo's Avatar
GLE 350
Here is the full wheel, I need the center cap.  The dealership searched it by VIN and it came back with the one in my hand which isn’t an exact match, the flutes are smaller than mine.  They also searched the VINS of the 2 they had on the lot that matched and came back to the same part #
Old Mar 16, 2025 | 04:44 AM
miszaa's Avatar
Hi ,
Is this what you looking for : A00040042009283
Check this part number should fit to GLE V167. This item look the same for various car models on photos but part number vary depends on the model as I see
Saw couple of them on ebay
https://www.ebay.com/itm/256643189855
BTW The price is frightening
Old Mar 16, 2025 | 11:04 AM
HotRodW's Avatar
2021 GLE450
It's possible MB changed the design, but that wouldn't explain why they're using the old design in new vehicle manufacturing. It's also possible that the one you purchased online isn't authentic. I have some non-OE aftermarket center caps msyelf that are stamped with the OE part number even though they're cheap knockoffs.
To be clear, you're just looking for the center cap itself, correct? You don't need the entire hub cap assembly?
Old Mar 16, 2025 | 11:10 AM
taphil's Avatar
2024 GLE63s, 2021 E63s, 2018 GLC43
nevermind.
HotRodW's Avatar
2021 GLE450
If the dimensions are correct this looks like a match ...
https://www.etsy.com/listing/1839945...1&gao=1&&gQT=2
Old Mar 17, 2025 | 03:31 PM
wildta's Avatar
GLE 580
Is the part number stamped on one of your existing ones?
Old Mar 17, 2025 | 04:31 PM
billjo's Avatar
GLE 350
It's possible the ones that I bought other than directly from MB could've been fakes but they all match the ones I got at the dealership.
I do only need the center cap but I can't read the part # on it because it was broken they they stole it, I'll pull one of my other ones off to look. The dealership said they go by the number on the "saucer part" but that doesn't mean he was correct as I've bought sets that matched that part #.
