GLE 53 Loaner
Lemme guess---- about 1,500 miles? Boss's spouse's demo, exchanged for next, and put into Loaner "retirement."
But you are very familiar with the 450 and you’re saying the 53 is that much faster is an interesting point.
It’s not just the engine and exhaust sounds that make it sound mean and fast, right?
The reason is the electric supercharger, which is designed to spin up and be at full boost a second and a half prior to the turbo kicking in.
In either case, you have the EQ boost, but the horsepower and supercharger is where it's most notable.
Good to have both but should had brought the vehicle over if she misses it that much.
In essence, it appears that it overrides your comfort/sport settings and puts it in Sport Plus if you smash it.
I find that useful, but the associated drawback is that now you're in Sport Plus and it will stay in whatever gear it has selected (downshifted to), thinking you're going to be continuing in your "Sporty" behavior. (Hung shift, or delayed upshifting.)
It also adds to the transmission learning algorithm, and IMO might contribute to some of the harsh downshifting that we've seen on the forum.
It sure is tempting to smash the pedal though....
If I hit the rev limiter there is a full second + delay before the fuel turns on again.
In manual, I spend too much time watching the tachometer, and end up short shifting for the most reliable performance. There is a significant response delay in a paddle shift, AKA "slow."
OTOH automatic mode does a great job of revving to 6300 RPM and shifts are very quick.
Downshifts are appropriate and provide good engine braking and I stay in the power band.
I'm not sure I agree that the 53 is designed for low speed performance, but it does run into a lot of wind at about 115 mph. With the windows down as required for track use, that speed is reduced to 95 MPH.
A 53 certainly does not have as much power to overcome Aerodynamic drag as a 63, and it's nowwhere near the fastest in its sector, but I think it puts us 429 horsepower to work pretty well throughout the Rev range.
If I wanted more I'd probably get a Brabus 500 kit. My service manager says that his customers with that kit are impressed and happy.
As for the 53 and 63 differentiation, we actually had a discussion about this in the AMG Private Lounge and AMG chimed in with exactly what I said. The 53 are optimized for low end performance and the 63 for top end performance. The 53 is basically more livable and handles daily driving better than the 63. The 63 is most at home at high speeds and on open roads. It's partly why I don't really daily mine. Tooling around in stop & go, city traffic etc. is not its forte.
EDIT: Just to clarify, the GLE 63, GLS 63 and G63 are the outlier 63 models that don't use the MCT, and instead rely on the TCT like the 53 models.
I could see that as improving the 63 around town performance.
There is also what I consider the overly harsh suspension on 166 AMGs, and the improved chassis combined with AMG ride control on the 167s.
Do you think the AMG statement applies to the newer versions?
