GLE Class (W166) Produced 2015-2019
Is 275/45/20 a proper replacement option for 265/45/20
Old Oct 29, 2016 | 11:31 AM
yavor's Avatar
Mercedes GLE 350d 4Matic
Does anyone have experience with 275/45/20 tyre size for his GLE? The car comes standart with 265/45/20 summer tyres and I think of placing 275/45/20 winter ones. The reason is 275 is much more common size and the options are more while price is lower. If I place it on 275/40/20 the clearance will be slightly smaller which is not ok for winter, while with 275/45 it will be higher with 10 mm. The question is apart from the slightly incorrect numbers of the speedometer, will there will be any problem for the car itself changing the tyre size to 275/45/20?
Old Oct 29, 2016 | 05:19 PM
cmginc's Avatar
I run this size on my ML550 with no issues... more than a year now.
Old Oct 30, 2016 | 04:35 AM
yavor's Avatar
What rims do you have? My major concern is that according to specialized websites the widest tyre you can safely place on 9 inch wide rim is 265. All 20" MB rims for the ML/GLE are 9" wide, including the AMG ones, only third party rims can be wider. Thats why I want to have real info from owners who have put 275 tyres on their 9" wide rims.
Do you think the airmatic will have some problems when determining the ground clearance according to a certain speed since the clearance is different from standart because of the tyres?
Old Nov 2, 2016 | 08:18 AM
yavor's Avatar
Nobody has any idea if 275/45/20 is gonna create any problem on the vehicle?
Old Nov 2, 2016 | 03:52 PM
E55 KEV's Avatar
Veteran: Air Force
2024 GLE63s / 2016 GLE63s (traded) / 2016 E63s / 2002 E55
Looks like cmginc answered your question? You can run the numbers here:
https://tiresize.com/calculator/
Old Nov 2, 2016 | 04:02 PM
yavor's Avatar
It's clear how to calculate the tyre dimensions, the question is if the car will suffer if I raise the ground clearance with 0.5 cm with the wider tyres or not. Because of the higher center of gravity in correspondance to the airmatic suspension.
Old Nov 5, 2016 | 03:36 PM
cmginc's Avatar
I have AIRMATIC and run the tires on 9" wide 20" AMG wheels with no issues - Yokohama Parada Spec-X.
Old Nov 6, 2016 | 02:11 AM
yavor's Avatar
Can you please post the exact size of the tyres,how wide and tall they are?
Old Nov 6, 2016 | 10:14 AM
cmginc's Avatar
I have already stated this... P275/45/20.
I am not sure what you are looking for here but I have given you all of the information you requested with real-world experience behind it.
Old Nov 6, 2016 | 11:02 AM
yavor's Avatar
Thank you.
You can check but you didn't mention the exact size of the tyres, that's why I asked again.
Old Nov 6, 2016 | 11:21 AM
E55 KEV's Avatar
Veteran: Air Force
Originally Posted by yavor
Thank you.
Really?!
Old Nov 6, 2016 | 11:29 AM
yavor's Avatar
I didn't answer to you but to the other guy.
Have a nice day.
Old Nov 6, 2016 | 04:24 PM
cmginc's Avatar
Really?!
Thanks E55 KEV
Old Dec 5, 2016 | 05:27 PM
Greybenz's Avatar
Gle350d 4matic
275/55/R20
hello, i got on my gle350d airmatic a pair of yokohama geolandar at g012 275/55/r20, in the front dont get to much tire rub, but at the back gets more.. not to much, sport mode gets less.. good choice for who need some off road tracks.
just to know this car fit until 31'9 wheels inch. But is need to check the tire rub, in my benz i have some litle damage in the plastic area inside the wheels.
Old Dec 5, 2016 | 05:40 PM
E55 KEV's Avatar
Veteran: Air Force
Sounds like you need to remove those tires immediately.
Old Dec 5, 2016 | 08:31 PM
Greybenz's Avatar
Gle350d 4matic
Dont need to remove, all is going good.
