GLE Class (W166) Produced 2015-2019
2017 GLE350 4-Matic headlamps
Old Jan 20, 2019 | 12:17 PM
leafseh's Avatar
2009 CLK350 Cab
I just bought a used GLE350 for my wife. Sister car to my 2009 CLK350 Cab. My bad I did not research something so simple as headlights and how bad these are - experienced the horror last night. Can someone net out for me my options....upgrade bulbs in current system (which bulbs)....upgrade light system - can dealer do it (I don't want to rip it apart myself). all suggestions are welcome.
Glen
Old Jan 20, 2019 | 01:14 PM
chassis's Avatar
2017 GLE350 4MATIC
Have a read through this to see if it is an option for you: https://mbworld.org/forums/gle-class...d-success.html
Old Jan 20, 2019 | 02:14 PM
AZN Optics's Avatar
SPONSOR/MBworld Guru
We have a kit we custom assembled with forum community assistance that will work perfectly with your SAM for plug and play functionality.
Hybrid HID kit
Old Jan 20, 2019 | 03:14 PM
leafseh's Avatar
2009 CLK350 Cab
Thank you,
I saw that post last night....not sure I want to get into taking off wheels...1/2 day jobs etc.
Glen
Old Jan 20, 2019 | 03:15 PM
leafseh's Avatar
2009 CLK350 Cab
What are the steps to install? Need to splice wiring; remove tires for access etc?
Old Jan 20, 2019 | 04:04 PM
leafseh's Avatar
2009 CLK350 Cab
So....Philips 9006 Crystalvision; Philips H7 ; Philips H7 White Vision 3700k Halogen bulbs with Xenon effect; Syvania Silverstar or other bulb options to at least improve this mess??
Old Jan 20, 2019 | 08:38 PM
kombifan's Avatar
2010 Mercedes GL450; 2000 Mercedes ML55 AMG; 2016 VW GLI SEL Stick!!!
Azn optics is the best for what you want. Plug and play. No wheel liner removal or splicing.
Reasonably priced too
If you choose oem hid bulbs you'll need the adapter from your dealer to fit them. I would go philips xtremevision.
But 't he Azn optics kit is morimoto and apparently they are really top notch
Old Jan 20, 2019 | 09:09 PM
AZN Optics's Avatar
No wire splicing. Kit designed to plug into existing own plugs. You just need access to existing bulbs and if you can reach it to change halogen, you can reach it to attach HID.
Old Jan 20, 2019 | 09:34 PM
leafseh's Avatar
2009 CLK350 Cab
Thank you very much
Old Jan 27, 2019 | 10:27 AM
leafseh's Avatar
2009 CLK350 Cab
You mentioned these are 35w (OEM are 55w) How hot do they run? I have seen 55w Sylvania Silverstar zXe Xenon filled Halogen - problem is they run at 200 degrees celsius so they would melt the lens. How hot are your lamps compared to OEM temperatures (basic halogen)?
Old Jan 27, 2019 | 04:32 PM
nvsocr7's Avatar
GLE 350 4MATIC
You'll be fine. A lot of us have been running these and haven't had any issues. I'm going on 3 years.
Old Jan 27, 2019 | 06:02 PM
leafseh's Avatar
2009 CLK350 Cab
So how and where did you mount the ballast on each side?
Old Feb 22, 2019 | 11:23 AM
Bimmer777's Avatar
2010 GL550, 2013 C63
Just bought a GLE350 and ordered this kit. Hoping for a smooth install.
