GLE63 shift paddles compatible on GLE350 steering wheel?
/J
https://www.autotrader.com/cars-for-...lickType=alpha
Check photo 25 of 34 in the above listing for the GLE63 paddles.
https://www.autotrader.com/cars-for-...Type=spotlight
Check photo 12 of 26 in the above listing for the GLE350 paddles. Not the same to my eye. Has anyone retrofitted the 63 paddles into a 350 steering wheel?
As johbe646 notes the part numbers are different. The photos are different. The paddles must be different. I think there is a 63 at my local dealer, I will take a look.
Anyways, from my experience with wheel/paddle swaps over on my W204 C63, if the airbags are the same, and switch setup is same, then as a rule of thumb the entire steering wheel will swap and be compatible. Now, as for just the paddles, I'd say there's a good chance the 63S paddles will fit. Not sure what part numbers you guys found when looking at the diagram, but I found the following at $158. Note all the various models it says it's compatible with. So, at a $158 experiment, someone should try it. I bet you'd be able to tell rather quickly without even opening the package if the paddle will fit in the 350 wheel. You could order from a place with a easy return policy etc. [EDIT] You can always check these out too, had my eye on them for my C63. Looks like they have the right fitment but I'd call and inquire: https://autotecknic.com/collections/...14469567348778
https://www.mercedesbenzstarparts.co...Y4LWdhcw%3D%3D
Our new 2016 GLE. I'm very pleased with it.
