GLE Class (W166) Produced 2015-2019
2017 GLE front fluid wiper not working
Old Jul 25, 2019 | 10:17 PM
Chao Hang Lu's Avatar
gle
The fluid wiper is not coming out any liquid. I checked there is still liquid and fuses are still good. What other place I can check?
Old Jul 25, 2019 | 10:55 PM
chassis's Avatar
2017 GLE350 4MATIC
Do the windshield wipers work in all speeds?
Does the rear window wiper work?
Does the rear window washer work?
Do the windshield wipers move when you press the windshield washer button?
Try pushing the windshield washer button many times.
Fill the the windshield washer bottle 100% full.
Old Jul 25, 2019 | 11:06 PM
gle
Hi chassis thank you for replying.
Yes the windshield wipers work in all speeds.
Yes the rear window wiper and washer worked.
Yes the windshield wipers move when I press the windshield washer button.
Old Jul 26, 2019 | 12:15 PM
chassis's Avatar
2017 GLE350 4MATIC
If the rear window washer (fluid spray) works, something is not right with the windshield washer system.
Start at the fluid reservoir and confirm mechanical connection of everything.
With a helper, do you hear the washer pump running when the washer button is pressed? You need to do more diagnosis.
Old Jul 26, 2019 | 12:59 PM
gle
So when pressed the washer button I don't hear anything. When pressed the rear window i hear the buzz noise. That's normal sound. Is anything any other testing i should be debug to determined the problem cause?
Old Jul 26, 2019 | 01:12 PM
Chefcct's Avatar
2016 GLE 350 4-Matic
OMG- Take it to the dealer! It is under warranty!
Old Jul 26, 2019 | 01:18 PM
gle
Really not sure if the warranty event covers it. Ill check that out.
Old Jan 12, 2026 | 04:59 PM
AutoTechED's Avatar
Multibrand
if your rear washer is working its just a simple problem most of GLE model have a singe washer jet pump.. just check your front washer pipes connection for clogged or disconnected part. That's it.
