My 2016 GLE350d Transmission Issue
I have a very frustrating experience trying to have the issue fixed. Dealers were always saying they can't reproduced the issue until 2 months ago, they finally figured out there was an electro hydraulic controller unit failure and they replaced it.
After that, the noise/vibration got improved but still there if I drive the car long enough (over 20 km).
I suffered from the issue for over 3 years since I bought the car brand new.
I am in desperate need of your advice what I should do next. I don't think it's fair to have the issue passed this way unnoticed without any further attention from Mercedes.
I heard from an Mercedes thread that the 9G Tronic does not pair well to the high torque diesel engine used on GLE305d. If that's the case, this issue could be common to other users, but haven't found any complaints from other users.
Your advice is really appreciated.
low vehicle speed
high vehicle speed
heavy throttle pedal
Light throttle pedal
when the brakes are applied
on rough roads
on smooth roads
when turning
when driving straight ahead
when stationary in a car park with the engine idling in P
when stationary with the engine idling in N and in D
low vehicle speed
high vehicle speed
on rough roads
on smooth roads
when turning
high vehicle speed - Only observable between 100-120km/h with D8
heavy throttle pedal - worse, but only with D8.
Light throttle pedal - better or disappear
when the brakes are applied - better or disappear
on rough roads - not relevant
on smooth roads - not relevant
when turning - worse and can get grinding noise in a curve. Only with D8 and speed 100-120km/h. Same with going uphill.
when driving straight ahead - not better or worse
when stationary in a car park with the engine idling in P - No issue
when stationary with the engine idling in N and in D - No issue
Another observation is before the electrohydraulic controller unit was replaced, the noise and vibration was happening (or more pronounced) between 115-120km/h. After the replacement, the noise is improved and but still obvious between 100-110km/h and less obvious between 110-120km/h. And the grinding noise is not as frequent as before. It was observable though when uphill or in a curve.
Really appreciate your help!
If something is wrong in the front differential or center differential, in what case can it be related to certain gear such as D8?
Is the vibration or sound worse when turning left, or when turning right? A wheel bearing could be something else to think about.
do you have any oil dripping on the ground or oil weeping from the front axle or transfer car? Need to get down on your hands and knees with a bright flash light to check.
I still think the issue is related to the transmission, as I mentioned earlier, they have found the failed electrohydraulic controller unit in the transmission and replaced it. And after that, the noise is improved. So now it is even harder to convince them that the issue is not completely fixed as you have to drive fairly long time to get the noise which the dealer is not willing to do.
As the car is still under warranty, I don't want to go to a local garage as that may void the warranty and I have to pay myself, which is not acceptable.
Thanks.
Mercedes are telling me it has not been found and that there is nothing wrong..
Please tell me you got it fixed eventually?
Humming under throttle only means propshaft joints or support bearing.
Humming under both throttle and no throttle means wheel bearing.
I may have to take legal action if they don't do anything.
I wonder did this ever get fixed?
I'm pretty sure the X166 uses similar bearings as the earlier X164 in the front diff.
This was a huge common problem and sounds very similar to what is described here.
Has anyone here had their front differntial or transfer case replaced or repaired for this or similar issue?
I would inspect the drive shaft or universal joint. I'm not sure if it could be the Flexible Disc that is mounted on the drive shaft.
