GLE Class (W166) Produced 2015-2019
LED or HID ?
Old Nov 7, 2019 | 09:53 AM
djfredmiami's Avatar
2012 GL 450
LED or HID ?
I wanted to upgrade stock halogens on a 2016 GLE350. led seems easier because we don’t need to drill the dust cover and install ballasts. But I wonder how reliable LED Bulbs are, how hot they can get, flickering, error messages etc. if you could share your experience and what brand worked for you.. thanks !!
Old Nov 7, 2019 | 10:27 AM
AZN Optics's Avatar
SPONSOR/MBworld Guru
If strictly looking at east of install, LEDs will be. However, you will see a big difference in performance due to light spread. You'll get better performance from HIDs over LEDs for sure because HIDs have true 360 light output that your halogen housing can better utilize vs LED point dispersion light spread. Heat will also be an issue as with LEDs, it's encapsulated inside the headlight, while with HIDs, the heat it mostly at the ballast/canbus component which is outside of the encapsulated headlight and can leverage natural engine airflow for cooling. LEDs you have two forms of cooling... one that has the big fan on it, but the problem with exposed mechanical parts is that it's something that tends to get clogged and fail unless you're diligent about cleaning. The other is passive ribbon cooling which basically uses long ribbons as heat sinks. Not as efficient as fan, but more reliable.
Let us know if interested as we've custom put together this Hybrid HID Conversion kit with the help of the MBWorld community as a best fit for Gx/Mx class MBs working specifically with your front SAM.
Old Nov 13, 2019 | 07:42 AM
Scott Minor's Avatar
2019 GLE43 SUV
Beamtech
Has anyone seen these new CSP LEDs? Supposed to have 360 light and low heat.
Old Dec 26, 2019 | 08:08 AM
amusa's Avatar
16 GLE400 4matic
When I had my CLK. I went thru allot of Chinese brand HID's all of them set off the CAN-BUS. I even had the canceler install (should of went with MTEC HID kit). Years of troubleshooting. I gave up and went with the Raych T1 Turbo Fan LED from Amazon and use the canceler on them and never had an issue with the CAN-BUS. I prefer the LED's over HID because HID needs time to warm up to get there full brightness.
Since I traded my CLK to the GLE. My GLE came with the OEM factory lighting package.
Old Dec 26, 2019 | 11:12 AM
AZN Optics's Avatar
COB has been making CSP LEDs for a while and leading the industry. SMDs still have higher luminosity compared to CSP, but has been something we've been keeping a close eye on and working with part manufacturer OEMs to track improvements. Heat is the same as heat issues are independent of the actual LED chip... Heat resides in the resistors which you'll have regardless in a canbus design.
Old Jan 17, 2020 | 04:13 PM
RRnelcheeze's Avatar
CLS55
Do you have an LED solution for the Halogen GLE's? would the Morimoto 2 Strokes fit?
Old Jan 17, 2020 | 04:58 PM
Chefcct's Avatar
2016 GLE 350 4-Matic
Does anyone have a dictionary to De-code AZN Optics post? COB,CSP,SMD, YEESH!!
Old Jan 17, 2020 | 05:20 PM
AZN Optics's Avatar
We have an H7 LED kit yes. The Morimoto 2 stroke won't work because it is not a canbus enabled kit. You'll throw errors.
Yes, it's called Google 😉. COB means chip on board and is the evolution of smd (surface mounted diode). COB will Have multiple mini diodes in one lighting structure, while SMD is basically a single large diode. CSP (chip scale package) is similar to SMD, but different wiring path that can reduce heat issues as it's plugged in directly to the chip board and not wire soldered in.
Old Jan 19, 2020 | 10:25 PM
Chefcct's Avatar
Michael, This is just my opinion for you...
Sometimes people get so enmeshed in their field that they forget that there is a lot of jargon or acronyms that they use daily that most people don't have any idea of the meaning. I always tried to remember that as I was a teacher in a technical field. Thanks and be well! Chris
Old Jan 19, 2020 | 11:17 PM
AZN Optics's Avatar
Totally get that. My response was made with a sense of humor (hence the emoji), nothing malicious. I threw in some higher level explanation, but when I originally threw out those keywords, my hope is also for people interested in learning, it'd serve as a basis for self searching and research. Having been on MBWorld for well over a decade, the people who find their way here are well educated and pretty self motivated. This forum is a superb resource for research and is highly technical compared to the other MB (or even other automotive) forums. Either way, always up for helping and explaining
Old Jan 21, 2020 | 03:40 PM
CLS55
i wonder if there is room in there for the CANBUS modules...?
Old Feb 4, 2020 | 08:21 AM
The Alchemist's Avatar
2017 C63 coupe
My fiance bought a 2016 GLE 350 this past fall, and compared to the HID's in my C350, it's pretty sad.
AZN Optics, I just want to make sure that the bulbs will mount properly as I've read that the clips and brackets need to be modified to fit. Does you kit include everything needed for a truly seamless fit, or do I need to do some modifications to get it working properly?
I want to upgrade her lights for valentines day, so looking to do this asap.
Brien
Old Feb 4, 2020 | 08:49 AM
Atlanta AMG's Avatar
GLC 63 AMG
Brien
I just installed the AZNOPTIC kit on my 2016 GLE. I Took it to a shop and they said initially it was the wrong kit because of the bracket included. I went back home messaged the vendor. In fairness he responded quick with advice, but I was expecting a direct fitment oem plug and play kit when I bought the kit and basically with this kit you have to take all the connectors apart, feed the bracket through the wires of the kit, seat the bracket against the bulbs which doesn't lock into place but rather just barely tightens up to in what I'd call 70% fitment, then you can install the bulb in the headlight. My installer also said that with this bracket it's the 'wrong type' and again the fitment in the housing was 70%, however after a 3 hour install of figuring all this out, I will say it looks and works good now however I've just had it installed a few days.
To be fair again, the vendor responded quick with advice to aid the install, I just wish the non oem fitment and non plug and play traits were explained before purchase and not as a surprise after I went to a shop and wasted my time etc. If this would've been explained as needing modification and moderate to high level of difficulty to install I wouldn't have bought it and would've continued my search for a oem+ solution.
Old Feb 4, 2020 | 09:26 AM
2017 C63 coupe
That's my concern. I don't mind having to cut a hole in the dust cover, or do the wiring, it's the actual fitment of the bulb in the housing that I'm concerned with. If it needs a different bracket or retainer, tell me up front, I don't want to be bending and hacking it up to get it to fit.
Old Feb 4, 2020 | 09:41 AM
GLC 63 AMG
The dust cover will have to be cut or drilled to get the wires through. And you'll have to take the pins and connector out etc. But the fitment of the bulb in the housing....my installer didn't have to modify that but he just said it didn't oem like fitment. It didn't have the prongs and the right tabs to lock it into place like oem, however he said it was like 70% fitment. Take that for what its worth, idk. My kit works fine so far, however I've been concerned a bulb will come out and get loose lol.
AZN Optics's Avatar
One of my customers will be posting step by step instructions with pictures today on kit install. This kit was assembled with assistance with the GLE forum community so does fit and function just fine. As soon as he posts it, I'll link to the thread here.
Old Feb 4, 2020 | 10:29 AM
2017 C63 coupe
Great. I'm no stranger to working on cars, I've stripped my trans am to a rolling chasis and rebuilt it completely, it also an hid upgrade kit on it, so I'm familiar with how it's done. I just want to ensure the bulbs fit properly into the housings because in a projector it makes a big difference.
Old Feb 4, 2020 | 01:09 PM
AZN Optics's Avatar
Here's the post: https://mbworld.org/forums/glc-class-x253/770274-2017-glc300-hid-install-pics.html
Old Feb 4, 2020 | 01:50 PM
GLC 63 AMG
I can't tell, is that vehicle a GLE350?
The person who wrote that post also mentioned not needing any adapter and the bulb had oem direct fit. So...not sure if that post is actually indicative or relevant to the install on a different car with a several additional installation steps. Does that mean I received the wrong kit and should have gotten a kit without an adapter and WITH oem direct fitment as well? Very confusing...
Old Feb 4, 2020 | 01:54 PM
2017 C63 coupe
According to the title, it's a GLC300. So different vehicle, but I'm guessing similar enough.
Old Feb 4, 2020 | 02:02 PM
GLC 63 AMG
I was being a bit facetious.
Your concern was the bulb going into the headlight, and for the GLC300 application it seems it's a different type of fitment than our cars. I think it's a bit misleading to link to an article where the same product does not install in the same fashion as our cars.
Old Feb 4, 2020 | 04:14 PM
AZN Optics's Avatar
Yes, it is a GLC, but point was it was outlining the process for install. It's the same kit. We include the universal euro bulb retainer for those who might need it, but quite often, they will fit with existing retainer. That'd be the only variation between the GLC instructions and your GLE install. So understand from our perspective, when someone buys this kit from our website, we don't know exactly which vehicle they're buying it for. We used to not include the retainer clip as it wasn't always necessary, but to ensure that there's a viable solution regardless for our customers, we later chose to incur the cost of the retainer clip and just include it with the kit at the same price point. If you didn't need it, well, no harm no foul.
Old Feb 4, 2020 | 04:21 PM
AZN Optics's Avatar
And this was the thread that really kicked off the work we did with many of the GLE forum community to piece together this kit in it's current iteration:
https://mbworld.org/forums/gle-class...d-success.html
Old Feb 4, 2020 | 06:57 PM
Chefcct's Avatar
AZN,
I think the point is---With something so complex and ultimately necessary on an expensive vehicle, unless the instructions are perfect and crystal clear, many people will be scared away to try this. Putting a GLC video up there did not help your case to assuage any fears in my opinion.
Old Feb 4, 2020 | 07:55 PM
AZN Optics's Avatar
AZN,
Fair point. I just wanted to show you another data point, not the end-all-be-all data point. I don't expect you to take my word that it works so tried to provide peer posts already from customers attesting to the functionality of the kit to backup my statement. It is a universal kit that we custom assembled to work with the GLE community as our initial batch of testers, but have validated it through nearly all other MB makes and SAM controllers. As it is a combined kit, we have the published install instructions from Morimoto and Hylux that we can provide as well as well as walk our customers through the install process.
Maybe we should take a step back and start over though.... What exactly is your concern? Challenge of install? Compatibility? Performance? Once I understand that, then I can focus my response.
