GLE Class (W166) Produced 2015-2019
Best Brake pads/rotors for GLE?
Old Apr 14, 2020 | 04:48 PM
graffixnyc's Avatar
2024 GLE 450 4MATIC
Hi all,
I've had my used 2017 GLE for a few months now and when I had my last maintenance they said I had enough left on my brake pads to last a while but I figured I'd start researching them now. What are the best(highest performance) pads I can get for my GLE? Also for rotors, are there "better" ones than the original ones? Or is it better to just get original rotors from MB?
Thanks in advance!
Old Apr 14, 2020 | 05:16 PM
hessank's Avatar
2016 GLE 350d Coupe
I also have been researching maintenance parts (brakes, wipers, battery, tires etc)
Funny that I've seen rotors for my car range from as low as $40 to $120 per rotor (Fleabay).
I believe your job is to find out where they are made and stay away from the Chinese brands (poor quality).
Stick with German (Brembo) or good old USA (Duralast, EBC or Power Stop etc...).
Best pads are probably ceramics
Check with Rock Auto, AutoZone, Pepboys etc (No affiliation).
Good luck
Old Apr 14, 2020 | 08:06 PM
Rainers's Avatar
I stayed away from ceramics becuase I noticed a big difference on both my e and ml class.
there are articles on ceramic vs semi metal that you should read. Ceramics for me took long to stop and the bite was too hard when I slammed the brakes.
try FCP EURO they have a buy once guarantee so if the pads or rotor go to **** in a couple of months you can replace and try again for free.
Old Apr 15, 2020 | 09:23 AM
hessank's Avatar
2016 GLE 350d Coupe
Good to know about the ceramics.
Old Apr 15, 2020 | 12:39 PM
Chefcct's Avatar
2016 GLE 350 4-Matic
I will throw in my two cents...
i have had many cars and tried many aftermarket brands of pads and rotors as well as OEM products. Since I do not drive on a racetrack, I have never seen a large enough difference to justify going with aftermarket. Especially with the Mercedes pads and rotors. They shed a little dust but not too bad compared to many I’ve owned.
My rear rotors got to 60,000 miles. My front rotors at 70,000 are still the originals, and still going.
So, the car stops great and is very controllable with the OEM pads and rotors...and I am getting a lot of mileage out of them compared to many I have owned in the past. I see no reason to change from OEM. Voila, my two cents for what it’s worth...
Old Apr 17, 2020 | 12:21 PM
Eurocar11's Avatar
2024 GLE450 & 2022 CLS450
+1 for Original Equipment (OE) brake components. Have tried non-OE brake parts over the years and was always disappointed. Mushy pedal feel, uneven wear, poor fit and finish, too much dust, squeaks and so on.
Figured the Mercedes engineers spent a fair amount of time and money developing the brake system and its components. Feel less confident the aftermarket stuff went through the same scrutiny.
Old Jul 11, 2024 | 11:39 AM
pincersbenz's Avatar
2017 AMG GLE43 4MATIC SUV
I echo those that have tried ceramic and failed...takes too long to stop and bite is hard 100% can agree. 2017 gle63s 6-piston brembos swap on my 2017 gle43amg
Old Jul 11, 2024 | 06:48 PM
BlownV8's Avatar
E55, GLS450, GL63, GLE350
My 63 with ceramics stops great. On other cars without huge calipers and rotors, the ceramics definitely take more pedal input.
Old Jul 12, 2024 | 03:54 PM
where do you buy/what ceramics are you using?
Old Jul 12, 2024 | 04:28 PM
BlownV8's Avatar
I use a combination of PowerStop ceramics on the front and EDC's for the rear.
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
