Necessary to change rotors with each brake pad change?
Thanks in advance for your help.
Additionally, the active lane keeping assist system consumes brake pads, to create a corrective yawing moment on the vehicle.
The brake "HOLD" function consumes brake pads, if you don't release it manually yourself by actuating the brake pedal. If, when using the HOLD function, you simply use the accelerator pedal to start moving again, there is a momentary consumption of brake pad as the driveline torque builds and the brake hydraulic pressure releases. It's not much, but if this is your normal method of operating the vehicle, it adds up over time.
in a couple yes when I need new brakes I’ll just order them and send the old back for 100% refund. I do this with oil and filter every year on both my MB and BMW
It cost monies to drive, skimping on basic parts to save a buck on a $70k SUV/SAV may indicate the wrong performance vehicle was purchased. That is not to say throw money at the $ealer, but don't skimp on replacing wear items to save a buck. Learn to do these basic jobs yourself and the labor savings alone will negate any parts prices. YMWV.
Rear pads were replaced at 35K, not sure why
they were bad at 35 and second pair last 2x times more.
Front at 90K
Rotor never, they were just perfect.
Car sold at 110K.
To OP: Changing rotors shouldn't add a lot of labors, if they are bad replace them as all others suggested.
