Brake pads + Spark Plugs + engine air filter
Went to the dealer for the “brake pad wear” warning ⚠️ I thought it would be the front pads (looked thinner to me) but the tech says rear pads need to be replaced, front look ok. I’ve never seen this before. It’s always the front pads wear off faster than the rear pads. Total $538 parr’s and labour for both.
Tech says based on my mileage, should replace spark plugs $864 parts and labour and Engine Air $162.
Is this on par with what people are paying ?
How often should spark plugs and air filter be replaced ? I read some people are going to 100K miles before Tune Up.
Also I was surprised that Spark Plugs and Engine Filter replacement is not part of any of the scheduled A B services. Don’t know if there are C or D
https://www.mbusa.com/vcm/MB/Digital...L_SLK_G_MM.pdf
I bought the spark plugs for around $120 from the local dealer. Add about 3 hours of dealer labor @$200/hr = mid $700. If I was off by 0.5 hours then you're at $800. Seems in the ballpark. I did my own plugs.
Engine air filter and spark plugs are 50k mile replacement items per M-B. Engine air filter is a breeze. Best to have the right kind of pliers from Knipex.
Rear brakes wearing faster than fronts is typical with M-B because assist systems, including basic cruise control, use rear brakes. My rear pads a bit thinner than the fronts, and I consciously avoid using assist systems.
"Standard" service is mainly engine oil, oil filter, wipers, top up windshield fluid, cabin dust and charcoal filters, and change brake fluid (every 2 years for brake fluid).
Spark plugs, engine air filter and transmission oil change are "additional maintenance work".
, I asked what’s the next big service and they said it’s transmission fluid change but hey said usually after 70K. I thought that engine air filter is part of B service but now see that’s only cabin filter.
I'm only at 7 k miles so far so not much wear yet....
A day after, Of course after i paid $1,500 for the service my dealer send this promo spend over $1,200 get $300 off.
here is how much I paid at the dealer
- Rear brakes replacement - labour $185. Parts $260, wear sensor, stop squeal, brake cleaner = $500 total
- Spark Plugs - labour $647.50. Spark plugs $147. Gaskets $69. = $863 total
- Engine Air filter - labour $100. Air filter $62. =$162 total.
I guess not bad at all at the dealer if you can time the promo specials then no need to go to a private shop mechanic etc
Did you get new rear pads, or pads+rotors for $260 in parts?
I paid about the same as you for spark plugs parts cost at the dealer.
So far, Fronts still original. I’m impressed with the longevity of the Brakes. Hope it stays that way. I would like to learn how to replace Engine and Cabin and Carbon filters but i don’t want to mess with MB stuff. Have done it on Toyota Camry and Honda Civic but this GLE is a different beast
