AC compressor discharge line weeping oil?
'21 AMG53 wDPP & ARC, 19 GLC300 - Former- 10&14 ML BlueTecs, 20 GLE450 E-ABC, 15 Cayenne D, 17 Macan
The dead system will not produce any pressure difference.
The overcharged system will fluctuate the pressure.
It will cool, but with compressor only on partial duty, it will not be efficient.
Than with system flexibility it takes a lot to overcharge it to the level of high limit clicking.
Even full can of refrigerant is not going to do it.
I suggested not to do anything, especially with leaks showing, to avoid the things you are talking about.
The constant cycling of the system stresses it, which ought to be avoided, even if the system is fine, which it appears not to be.
I think "trial" charging of AC without guages or knowledge is Ill advised.
chassis (09-19-2021)
chassis (09-20-2021)
Your "advice" doesn't apply here, since you keep referring to instrumented testing.
It sounds like you have some experience that could be helpful. How would you approach the original question without equipment?
1922 Ford Model T / no OBD
#32
#34
Maybe you could make it your mission to correct all those folks who aren't as delightful as yourself.
That could make your experience so much better. Think of all the stressful nights you'd save yourself! You wouldn't get so wound up when somebody posts a question, or makes a rational comment.
Take a deep breath. Then maybe you could be helpful, instead of disdainful.
