GLE Class (W166) Produced 2015-2019
Jerk when release the accelerator then step it again, happens below 20km/h
Old May 7, 2022 | 02:34 AM
raymond0229's Avatar
GLE320
Hi, All,
My car is gle320, petrol, 3.0T, 73000km now.
The car always jerk when release the accelerator then step it again, happens below 20km/h.
Checked by 2 dealers shop, no dtc found about the engine and transmission.
Does anyone have any ideas what this could be? or anyone resolved this problem?
Thanks in advance.
Raymond
Old May 7, 2022 | 12:37 PM
chassis's Avatar
2017 GLE350 4MATIC
Originally Posted by raymond0229
Hi, All,
Thanks in advance.
Raymond
Sorry to hear. Can you give a more detailed explanation? What does “release the accelerator then step it again” mean?
Old May 7, 2022 | 02:19 PM
Pappachoppers's Avatar
2022 GLE
I too purchased a 2022 GLE 350 that now has less than 120 miles. When I am accelerating at a stop sign/light I do so slightly to maintain an assured distance from the vehicle in front. When easing off the accelerator seconds later, I feel a thumping jerk. It’s not a smooth transition in gears. No other car I’ve driven gave this jerk..
Old May 7, 2022 | 03:16 PM
chassis's Avatar
2017 GLE350 4MATIC
@Pappachoppers Try starting a thread in the V167 section for your vehicle which is the latest GLE version. There are many people in the V167 section who can comment.
This is the W166 section for the previous GLE version.
Old May 7, 2022 | 10:20 PM
GLE320
below 20km/h, release the accelerator then step the accelerator, will jerk almost every time.
Old May 7, 2022 | 10:22 PM
GLE320
same issue.
Old May 7, 2022 | 10:44 PM
chassis's Avatar
2017 GLE350 4MATIC
Sounds like normal function. Mercedes transmissions are generally bad. This is an example.
Old May 8, 2022 | 12:27 AM
W205C43PFL's Avatar
As mentioned, normal behaviour. When you release your foot off the accelerator pedal, the vehicle thinks you wanted to slow down and the transmission is preparing for that, it believes you will soon be pressing the brake and therefore ready to downshift but instead you decided to accelerate again which confuses it..."Wait what, you wanted to accelerate?", so it has to get ready to upshift instead.
Old May 9, 2022 | 11:08 AM
amusa's Avatar
16 GLE400 4matic
Check your transmission fluid level (low fluid) and when did you replace the trans fluid?
