GLE Class (W166) Produced 2015-2019
9G Tronic transmission service
Old Jan 3, 2023 | 08:44 PM
nookie's Avatar
GLE350d, Porsche TE
Hey guys, for those who are interested;
(will add some more pics soon/update)
I just completed the recommended transmission service on the GLE350d @ 122000KM
For those who are thinking about doing this yourself, it’s not hard. but you do need some special tools,
TOOLS
Easier if you get the toolkit you can get on ebay for $10 shipped to your door. includes pan drain plug hex removal tool, and the hex tool to adjust the filler/drain valve positions 1-4
You’ll also need a fluid pump and some basic tools like jack and E10 torx
The PAN/FILTER $260.00
One Piece, plastic PN 725-270-37-07
Bolts and filler valve not included
The filler tube/valve
The filler valve PN 725-271-21-01 and accoustic diagnostic tube are sold separately for $40CAD but it’s possible to remove them from the old pan and can be reused. there’s no rubber seals in these parts.
THE OIL
MB 236.17 Specfication, MB charges a fortune for this, you’ll need about 5 liters. I bought of MB Dealer on ebay $100 shipped but don’t be surprised to pay 50/liter at local dealer.
If I had to do it again I’d just replace oil as the filter inside the pan is pretty coarse anyways.
PROCESS
You’ll need to lift/raise the transfer case about an inch as the back 3 bolts on the pan (E10) are above the a crossmember where your hands don’t reach.
do this by removing 2 nuts on the crossmember that hold the transfer case. jackup the transfer case and put a piece of wood between crossmember and transfer case. just in case your jack fails your hands won’t get crushed when you’re at it.
Then start by loosening the back 3 bolts from the pan. once you’re sure you can get to those remove the pain drain plug, put in the hex tool and turn the drain valve over to position number #4 (numbered on the pan) this will drain the pan, but about 1 liter will stay behind, that will come out when you remove the pan. Then remove the rest of the bolts and pull pan off. I pulled 4.5 liters out.
Install new pan with valve and guide tube and set fill valve to position number 1 to fill fluid.
I put 5 liters in. Torgue bolts to 4 NM then one more 1/4 turn.
Warm up engine and flip valve to position #3 and let it drain until it trickles out. then close valve to Position#1 (Fill)
THE VALVE
Has 4 positions
#1 FILL (opens highest point on tube)
#2 drain slow
#3 drain to level at temp
#4 DRAIN (opens lowest point on tube)
There is NO closed position, you close it by installing the pan plug. (comes with new pan)
Pan/Pump/Fluid/tool ran me about $500
There’s a video on youtube as well showing this process.
ToolKit $10
Fluid pump
Filler tube
Old Mar 12, 2023 | 07:35 PM
ZX81's Avatar
GLE 400
Thank you
Thank you for sharing this. I have a GLE 400 2018 - in GTA. Just crossed 50k kilometres so long way to go for transmission work.
can you please share the service schedule?
Thank you,
Old Mar 13, 2023 | 07:45 PM
W205C43PFL's Avatar
Thank you,
If in the GTA assuming you mean Great Toronto Area and not the game then this might be what you are looking for, kindly please see attached. It is for 2017 but might be applicable to the 2018, confirm if you have the 9G or 7G, 7G Plus then refer to this manual.
Old Mar 13, 2023 | 07:46 PM
W205C43PFL's Avatar
TOOLS
THE OIL
PROCESS
THE VALVE
Has 4 positions
#2 drain slow
ToolKit $10
Fluid pump
Filler tube
Great write up OP, thanks for sharing! Good job getting it done!
Old Mar 13, 2023 | 09:52 PM
ZX81's Avatar
GLE 400
Thank you from Greater Toronto
yes I am in Toronto and my GLE is the 9 speed one. Thank you for sharing
Old Apr 9, 2024 | 12:07 PM
Thangvan's Avatar
Gle 350d
Hi thanks for posting this. Did you reuse the 10 bolts on the pan or replace with new bolts? I'm confused as WIS doesn't say I need new bolts but some online instructions say new bolts are required
Old May 5, 2024 | 05:07 PM
Jrrrrr's Avatar
2023 Mercedes-Benz E-Class
Motive Power Fill with long fill tube for Toyota.
I have a Motive Power Fill with long fill tube for Toyota.
What do I need to use for Hooking up to 9G-tronic fiil tool?
take tube off then?
Old Jun 7, 2024 | 10:49 PM
Thangvan's Avatar
Gle 350d
How was the transmission after oil change? I've experienced hesitation in low gear from start, although oil level measuresd correct.
Old Jun 8, 2024 | 10:30 AM
W205C43PFL's Avatar
Would recommend resetting transmission adaptation after the oil change. Are you sure the oil level is correct (there is a specific procedure if I recalled correctly, the measurement must be measured at a certain temperature for example)
Old Jun 9, 2024 | 02:32 AM
Thangvan's Avatar
Gle 350d
I have Xentry and follow procedure in Xentry. I'm wondering if Xentry is accurate as I drained out about nearly 8l from gear pan and torque converter. I pumped in 6.5 l (manual recommend 7.5l).
Old Jun 9, 2024 | 08:07 AM
W205C43PFL's Avatar
It looks like you did the procedure correctly, the fluid used should be correct right? I would go ahead and do the transmission adaptation reset in XENTRY in that case.
Old Jun 9, 2024 | 10:54 AM
Thangvan's Avatar
Gle 350d
UPDATE for those who are interested, I think I relied on Xentry and it is not accurate. Possible reason for jerking when changing gears is not enough transmission fluid. I added 1.5l of fluid and now it is as smooth as feathers.
Old Jun 9, 2024 | 11:04 AM
W205C43PFL's Avatar
Interesting, strange XENTRY was wrong, glad you figured it out!
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
