GLE Class (W166) Produced 2015-2019
W166 replacement brakes milages
Old Jun 16, 2025 | 03:14 PM
amusa's Avatar
16 GLE400 4matic
Originally Posted by streborx
Brake pads don't wear while sitting in a box on a shelf or when mounted in a caliper and not rubbing against the rotor. There must be some explanation for such accelerated wear. Is very aggressive braking taking place? Or much stop-and-go driving in bumper to bumper rush hour traffic?
I think it's the material that the pads are using. That would be my guess. My second guess a seized caliper (still have not look at the passenger side to confirm it). I will know this Thursday since I have the 2 post lift reserved.
Old Jun 17, 2025 | 02:46 PM
amusa's Avatar
16 GLE400 4matic
Im now leaning towards a seize caliper
Driver rear
Driver rear
Passenger rear
Passenger rear
Old Jun 17, 2025 | 04:54 PM
chassis's Avatar
2017 GLE350 4MATIC
Can you shift or wiggle the caliper through the wheel, using a pry bar or stout screwdriver? Or take the wheel off and ensure the caliper moves freely on the slide pins.
Old Jun 19, 2025 | 08:18 AM
amusa's Avatar
16 GLE400 4matic
Both inner and outer pads are the same wear. We think the brake hose collapse. Right now we have to exchange the caliper since this truck has the AMG caliper and we also order a new hose and now waiting on (1) rotor.
Old Jun 20, 2025 | 04:29 AM
amusa's Avatar
16 GLE400 4matic
Update:
I replaced only the driver side rear caliper, rotor, pad, brake hose and cleaned up the brake dust front the hub and dust shield.
Confirm the brake hose collapse because when we try to put air through the brake hose it's being restricted. I'm going to keep monitoring it and if it happens again I be checking the electronic side.
Old Sep 23, 2025 | 03:56 AM
amusa's Avatar
16 GLE400 4matic
My worst luck
The brakes is squalling again (very loud) sounds like the same wheel Time to reserve the lift again to inspect and another replacement (I have a spare set of rear pads/rotors).
Old Sep 23, 2025 | 02:12 PM
  #32
amusa's Avatar
16 GLE400 4matic
Outer pads destroyed
Old Sep 26, 2025 | 10:49 AM
  #33
amusa's Avatar
16 GLE400 4matic
Update:
We took so many measurement's and we concluded it was the aftermarket caliper that was installed had the wrong size carrier (mounting bracket). We even order (2) more aftermarket calipers (AMG and non AMG) they all had the same size carrier. I notice the pads had an overhang above the rotor.
We order the correct carrier bought OEM Mercedes out of state since Mercedes in my area only will only sell us a complete caliper.
The GLE is back on the road after being down for 4 days since we were waiting on the carrier to arrive.
Lesson learned check the parts first before installing them. It was the aftermarket manufacture, QA screwed up.
