Cam position sensors/magnets may be leaking oil
Has anyone changed these seals? If so, what parts (seals only or did you change the entire cam magnet) do I need?
Did you also remove, clean and reseal both timing cover plates at the same time?
How difficult is the job?
If anyone is holding it, I would love to get a copy of the WIS for changing the cam position senors, seals and the timing covers.
Thank you, as always, for taking the time to respond and for sharing your experience and expertise.
Sensor and magnet replacement are trivial jobs. The challenge is gaining access. Note the screws need to be replaced and the torque spec is very low: 4Nm + 60 degrees.
Resealing the front cylinder head cover requires careful removal of old sealant with Loctite 7200 and avoiding damage of the textured surface from the manufacturing process. No sharp tools (gasket scraper)!
Search feature will give you dozens of threads on this topic. W212 E-Class and W205 C-Class use the same engine.
