GLE Class (W166) Produced 2015-2019
LED Fans Run Way to Much!!
Old May 3, 2025 | 09:19 AM
mrbreakout's Avatar
2016 GLE 350
Hi,
I recently purchased a 2016 GLE 350 with LED headlights. We noticed that every time we touch the car, (almost), the fans for the LED headlight fans come on, even if its been setting for days in the garage, engine cold of course. It's hard to understand MB's logic on this, as it gets annoying after a while.
Has there ever a Software patch or remedy for this? I'm open to coding this myself if need be.
Old May 3, 2025 | 10:17 AM
W205C43PFL's Avatar
Originally Posted by mrbreakout
Hi,
never heard of this issue with this model might be this particular car. Did you scan the vehicle for codes with Mercedes specific obd scanners? How's the battery condition?
Old May 3, 2025 | 10:31 AM
mrbreakout's Avatar
2016 GLE 350
I'm working on getting a scanner, but I dont expect to see a hardware issue as this was discussed over at Benzworld:
https://www.benzworld.org/threads/wh...-fans.2806874/
I was hoping there was a firmware update.
Old May 3, 2025 | 10:43 AM
W205C43PFL's Avatar
I see , maybe I am just bad at searching but I am not seeing such threads on mbworld though. That said, if it was software you could ask Peter (a third party coder) to check for it.
Old May 3, 2025 | 01:16 PM
mrbreakout's Avatar
2016 GLE 350
Sure, how could I find Peter?
Thanks!
Old May 3, 2025 | 01:52 PM
W205C43PFL's Avatar
Thanks!
His banner is on top of the forums, if you don't see it, try logging out.
Old May 3, 2025 | 07:20 PM
trigital's Avatar
W213 All-terrain
Till software update I would ask myself if there is a reason for doing like that...for example too much moisture..,
Old May 4, 2025 | 05:11 AM
ygmn's Avatar
2015 E400 Sedan
My 2015 E400 is about the same.
Look at car in garage and those pesky Headlight fans come on... and stay on for good while
ANNOYING to say the least.
I have a launch and could not find anything within to control fans.
My question for MB would be why and when do these fans operate.
Old May 4, 2025 | 07:47 AM
John Ha's Avatar
2016 GLE 300d 4-Matic
Hi,
Mine (2016 GLE 300d) does the same thing, although sometimes I don't even have to touch it for the fans to start - just walking into the room does it. I don't know why but it doesn't seem to hurt anything so I've not looked into it or done anything about it.
Old May 4, 2025 | 09:38 AM
W205C43PFL's Avatar
You mean the condensation that MB deems normal?
If there is no condensation, I wonder that is why the newer MB models don't have as loud of a fan (apparently people complained?) and how it is so common to see headlights fogged up?
Old May 4, 2025 | 12:46 PM
Chefcct's Avatar
2016 GLE 350 4-Matic
I don’t think they are the headlight fans. Because in my car when i come near it, I can hear an activation of some kind, but I think it has to do with the car looking for the keyless remote. Just my opinion.
Old May 4, 2025 | 02:11 PM
W205C43PFL's Avatar
Did you try to see if it still does it without bringing the key then?
Old May 4, 2025 | 04:47 PM
trigital's Avatar
W213 All-terrain
Yes, I was referring to condensation. The headlamp has sensors inside and the fans only try to ventilate.
Old May 4, 2025 | 05:05 PM
W205C43PFL's Avatar
I never hear LED fans on a W205 and they fog up a lot actually many newer MB models too. Did they get rid of the fan?
