GLE43 Coupe (C292) 2016 - Present (Includes GLE450 Coupe)
GLE 43 coupe couple questions
Old Jun 25, 2017 | 12:16 PM
barata_84's Avatar
GLE43 AMG COUPE
Hi all,
Purchased GLE43 coupe, very happy with it!
However couple questions maybe you guys can help out with:
1. How do you display your gauges on your main 8" screen?
Should it be under vehicle-dynamics-engine data? For some reason i don't have that option.
2. In my country it the car is not equipped with the touchpad. Possible to have it retrofitted?
Many thanks in advance.
Regards,
B_84
Old Jun 25, 2017 | 12:43 PM
GLE43_Sube's Avatar
AMG GLE43 Coupe
Originally Posted by barata_84
Hi all,
Regards,
B_84
Yes, you have the right location to show the gauges. I have no idea why it's not showing. What do you see when you go to that section?
I would imagine it's possible to retrofit a touchpad, but it would likely be expensive. You're in Indonesia, correct? I went to the MB ID website and the GLE43 Coupe is pictured with the touchpad.
Old Jun 25, 2017 | 02:16 PM
barata_84's Avatar
GLE43 AMG COUPE
FaMBGLE43AMGCoupe_Flyer210x297mm.pdf
Vehicle-Dynamic Select-
Is the option written just DYNAMICS?
The catalogue does show the touchpad but as you can see in the options below theres none mentioning touchpad. (also no surround view, just rearview camera)
Old Jun 25, 2017 | 03:18 PM
GLE43_Sube's Avatar
AMG GLE43 Coupe
It should be Vehicle>Dynamic Select>Engine Data.
Is your car like the one pictured, with the padded armrest extension leading out to the controller knob?
Old Jun 26, 2017 | 11:31 AM
barata_84's Avatar
GLE43 AMG COUPE
As per attached (no touchpad).
Picture above is where it goes after choosing Dynamic Select.
No option for Engine Data.
Should I go back to dealer and have it set up?
Old Jun 26, 2017 | 04:24 PM
BACnMercedes's Avatar
19 E63s, ‘24SQ8, wanting another gas guzzling V8
That looks backwards from everything else MB has done on the GLE. I'm curious to know why it's so different.
Good luck but I have no idea how to help other than what GLE43 suggested.
Old Jun 26, 2017 | 07:35 PM
GLE43_Sube's Avatar
AMG GLE43 Coupe
Picture above is where it goes after choosing Dynamic Select. No option for Engine Data.
Yes, I definitely would see the dealer. It could just be a software glitch. If it showed your set-up in your manual, that would be different. They could say, "Well, it's a different version in this country." But they need to explain why you don't have features you paid for.....features depicted in the owner's manual and on the MB Indonesia website. Your pic shows the "Individual" setting. That's something totally different.
As for the difference in hardware, check the other models on the dealer's lot. If none of them have a touchpad, then I guess they just ship a different version to ID.
Old Jun 27, 2017 | 12:39 PM
barata_84's Avatar
GLE43 AMG COUPE
Guess I don't have a choice but to go back to the dealer again.
Do you have a picture on what should be there after I selected Dynamic Select?
And the individual setting as well.
Thanks much!
Old Jun 28, 2017 | 07:33 AM
GLE43_Sube's Avatar
AMG GLE43 Coupe
Do you have a picture on what should be there after I selected Dynamic Select? And the individual setting as well.
Thanks much!
After you select "Vehicle" in the main menu, turn the controller until you reach "Dynamic Select". Press the controller knob straight "down" to select. On the next screen, you should get an entire page of selections including "Vehicle Data", "Engine Data" and "Individual Configuration". Turn the controller knob to "Engine Data". Press the controller knob straight "down" to select. You should now see the gauge display. If you turn the controller knob to "Individual Configuration" instead of "Engine Data", you can select that. That will bring you to the screen in your pic.
It looks like your car is "skipping" the entire "Dynamic Select" page and going straight to the "Individual Configuration" screen.
Hope this helps.
Attached Thumbnails GLE 43 coupe couple questions-dynamicselect.jpg   GLE 43 coupe couple questions-enginedata.jpg
Old Jun 29, 2017 | 04:27 PM
barata_84's Avatar
GLE43 AMG COUPE
Thank you GLE43_SUBE !
You've been a great help.
Old Jul 4, 2017 | 02:05 PM
barata_84's Avatar
GLE43 AMG COUPE
Hope this helps.
Just find out that mine is NOT equipped with COMAND SYSTEM nor TOUCHPAD.
This vehicle is so downgraded in this country. DAMN!!
Old Jul 4, 2017 | 04:24 PM
F18BEN's Avatar
Veteran: Army
2026 BMW 550e X DRIVE, 2024 GLE 450e SUV
Sorry that it's equipped that way. Hopefully the cost reflects the downgraded equipment. On a positive note, It's one less thing to break!!! Good Luck!!
Old Jul 4, 2017 | 05:22 PM
GLE43_Sube's Avatar
AMG GLE43 Coupe
Just find out that mine is NOT equipped with COMAND SYSTEM nor TOUCHPAD. This vehicle is so downgraded in this country. DAMN!!
That sucks!
I was hoping maybe we were just missing a step.
Old Jul 6, 2017 | 01:34 PM
barata_84's Avatar
GLE43 AMG COUPE
cost me 150k..
Old Jul 6, 2017 | 04:23 PM
F18BEN's Avatar
Veteran: Army
150K----US Dollars?
Old Jul 7, 2017 | 01:32 PM
barata_84's Avatar
GLE43 AMG COUPE
150K----US Dollars?
yes sir US$150,000
