Bad steering pull - 2018 GLE63 S...calling wheel alignment specialists
Has anyone experienced this and found a solution or settings that have made the difference?
The recommend tire pressures are much lower than what I am running unless the vehicle is fully loaded.
What caused the need for the first alignment? Damage? Hit a curb?
Replace all bent parts.
Align the vehicle at a dealer.
Enjoy the vehicle.
This does explain some of my problems, but that was in January and since then I have been winding in toe "in" into the toe rods. I started with 3 hex flats on each side then another 4 and it has helped but it still has not resulted in a neutral drive.
All the time I been thinking I started with 2.1mm of toe "in" (which I hadn't) and was feeling like I had gone about as far as I could. But now that I know it was Toe out, I got stuck in and gave it another 3 flats, went to 47.5lbs of tire pressure and went for a 240km drive on a mix of roads and surfaces and bingo!, I am happy to say I have a totally neutral drive. I gave my wife a drive and I said, how was that, did it pull? and she sad no its was just fine. I'm feeling very happy, but I am concerned I have added to much Toe in, the last 3 flats amounts to 0.75mm on the toe rod, its not a lot and I didn't think it would make such a dramatic change. Next step is to go back for an alignment to see what the measurements are and also fit the camber/castor bolts to reduce camber, because there is to much unless you are on a race track.
Using a tight nylon line string line along the side of the car and allowing for track width differences, I have measured about 5mm of toe in on the left and right. This will be outside spec, but you I cant argue with how it drives now.......lets see how we go.
BTW, I am going to try your tire pressure. My tires made it a whopping 14K miles and I now have 21K miles. I replaced the brake pads at 16K miles and I don't run it hard.
And, of course, the more worn your front end parts are, the more toe in you'll need to overcome the slop in the steering (drag puts a tow out Force on the assembly).
I'm not sure I'd agree about your camber corrections.
I do agree that the camber will wear the inner shoulders of the tires more quickly, but I think that only costs about 10% of the overall tire life.
I'll trade that reduction for the improved handling responsiveness, which I believe is important in evasive maneuvering even if you're not at the racetrack.
And when at the racetrack I want more camber.
Why not skip the camber bolts, go to the Mercedes dealer where they have the correct fixtures for your wheels, and get it set to factory specs?
As in "start over," because I think you've introduced too many variables and maybe too far afield.
Definitely throw away your string line! Too many variables for that to be effective anymore. Front and rear axles have toe in, which introduces yet another variable.
Good luck.
At factory alignment, the vehicle should not pull, drift or wander. If the alignment is at factory settings, and it pulls or wanders, parts are worn or broken and need to be replaced.
AMG SUVs have a tire eating problem. It's the nature of the beast.
We aligned my wife's C43 and my CL600. Both track straight and true. That' over $1K in alignment on 3 new vehicles and one used CL. Hard to believe but the CL was closest to nominal.
The reason for the excessive wear is no secret nor rocket science, there is a lot of camber resulting in the tire not being flat on the road, the wear pattern shows us this and I cant see any point in wearing the inside shoulder off and having max tread depth on the outside, when I drive on highways with some windy roads and I do some very windy roads.
Grip is all about the contact patch (if you ride road bikes you will know all about contact patches). Evasive maneuvers require a contact patch in the first instance otherwise its not going to happen, but because we don't know how much "camber gain" these vehicles have, or do do we??, it maybe a completely mute point anyway.
Go for a drive, stop and put you hands on the tire and check the inner and outer shoulders for temp difference, this tells you which part of the tire is contacting the road (the V8 race teams use this method to check alignment/contact patch). In my case the outer shoulders are cold, even on the road in the map below.
Here's the link https://www.google.co.nz/maps/dir/-3...!4m1!3e0?hl=en go and street view this puppy, its one windy piece of road and I was by myself pushing it. On my return trip I managed a semi even temp across the fronts, but at the same time the rears outside should was cold. This tells me that if I have less camber, I will get an even temp across my tires, increased tire wear/life and less steering pull, I call that a win, win, win. Nissan ask you if you want a street or a track setup, as one does not do all, well.
