20000 service came back and doors keep locking
Old Nov 19, 2022 | 10:12 AM
rhart6's Avatar
E63 sold, 1972 911S, '58 Speedster, 2021 GLE 63S, Turbo 997, Aston Martin V8 Vantage 69 911 Hotrod
When I park my GLE 63S in my own garage and return I want the all the doors unlocked like I left it. Been like that since new. Had the car serviced and when I leave the car
and return or just hop out to open a back door all the doors are locked. How do I switch it back to "keep doors unlocked" position?
Old Nov 19, 2022 | 11:48 AM
mikapen's Avatar
My "relocking" problem is attributed to inadvertently hitting a button on the fob, while it's in my pocket. More often, and more concerning, is opening the rear hatch.
Don't know if this is your issue, but I've re-thought how I carry my key.
The only thing I can think of that might change, is they normally replace the key battery with each service.
Maybe open and close the battery compartment and see if anything changes? Process of elimination....
Good luck.
Old Nov 19, 2022 | 02:24 PM
rhart6's Avatar
Thanks Mikapen
Been carrying the key same way for 2 years and no problem. I tried the remove cover thing but to no avail. I also went into the menu and clicked on and off the "lock doors" in the menu.
...and still it persists.
Old Nov 19, 2022 | 08:28 PM
Frenetic's Avatar
2025 AMG GT 63, 2023 S500, 2022 GLE53
Rharts, any advice you get from some people here is: USER ERROR with a side dish of passive aggressive contempt. I would just document and take it to the dealer so they can keep your car for a few days while they troubleshoot and confirm MBUSA will pay for for it. Good luck.
Old Nov 20, 2022 | 08:56 AM
rhart6's Avatar
I can see why you are a Super Member and love your Mark Twainesqe passive aggressive comment. Well said. Of course I plan to take it to the dealer I just hoped that
someone here would have an easy "just do this" kinda solution.
mikapen's Avatar
Originally Posted by rhart6
Thanks Mikapen
Well, battery and settings check are the only At Home troubleshooting thoughts I have.
Maybe someone else has an idea and will offer better advice. Interesting and strange problem.
Good luck!
Old Nov 27, 2022 | 12:28 AM
ahesq's Avatar
2021 GLE63S
OK, COME ON NOW...
1ST - YOU NEED TO LOCK YOUR CAR, PERIOD.
2ND - I HAD THE SAME ISSUE WITH THE TRUNK OPENING UP.
TURNS OUT THAT THIS BOTTON IS SENSITIVE, SO WHEN YOU SHOVE IT IN YOUR POCKET OR BRIEF CASE
IT WILL POP OPEN THE TRUNK, IF HIT THE RIGHT WAY.
LOCK THE CAR AND PUT YOUR KEYS DOWN ON A TABLE WHEN YOU GET HOME,
AND ALL SHOULD BE WELL THEREAFTER.
Old Nov 27, 2022 | 01:26 PM
mikapen's Avatar
Originally Posted by ahesq
OK, COME ON NOW...
That's a good solution, but it doesn't address the OP's needs, which include wanting all the doors unlocked in his garage. I'm the same.
It also doesn't work if you are just Out and Around, such as dining or shopping.
To your Keys on the Table idea, I've seen threads that claim that the car will sense a key proximity and never go to sleep, hastening battery drain. And the solution is to keep the key 100' from the car to prevent the "sleeplessness."
Do you or anybody else have input on that?
I know my awakens when I approach with keys, and doesn't if I arrive without the key.
Old Nov 29, 2022 | 12:20 PM
de31p5's Avatar
GLE53
Modern Mercedes keys have an accelerometer built in to put they key in sleep mode after inactivity for a certain amount of time, say, it sitting on your counter at home. This deactivates the key's constant transmission until it senses movement again. I believe this was a fix for the relay hacking car thieves used for some time.
You can test this out, leave they key nearby but unmoved (not sure how long) and the car will not respond. I've also done this with the key sitting in the cup holder while I'm cleaning out the interior, or sitting in a parking lot, when I'm ready to set off again, the car won't see the key until I physically move the key.
