Brake Caliper Mounting Bolt Torque
Old Apr 1, 2023 | 08:56 PM
FStephenMasek's Avatar
'21 AMG GLE63S, '17 BMW 340iGT
Help! I can't seem to find the torque specification anywhere. The bolts are metric 12 diameter, class 10.9. I've found torque charts (many, some too simple) which indicate that dry zinc-plated 10.9 M12 bolts should be torqued to 78.9 Foot Pounds. My 2021 AMG GLE63S has the Brembo-made calipers which have to be removed to change the pads.
2021 AMG GLE63S front brake
Last edited by FStephenMasek; Apr 2, 2023 at 10:50 AM. Reason: more information, fix Typo.
Old Apr 2, 2023 | 01:08 PM
jaxslk's Avatar
2025 GLE 450, 2022 AMG GLE 53
This is for code U70, which is the brembo unit on my 2022 GLE53. It's for a 2019 spec, but likely hasn't changed. 120Nm. Hth.
​​​​​​@chassis - or other more knowledgeable folks - is this right?
https://mbworld.org/forums/coupe-roa...ml#post7861712
Old Apr 2, 2023 | 01:31 PM
chassis's Avatar
2017 GLE350 4MATIC
Seems reasonable but one needs to decide for oneself. Because braking system maintenance errors can result in significant property and casualty damage, each person needs to do his/her own research and decide what is right, and what is not right. Or pay the dealer.
Or ask @konigstiger if he can access WIS for V167. Is WIS for C190 on this site somewhere?
Old Apr 2, 2023 | 03:14 PM
The brakes shown for your vehicle are not the same as those on mine. There is no need to remove the caliper to change the pads on your vehicle.
Old Apr 2, 2023 | 05:00 PM
jaxslk's Avatar
I have the red Brembos. Pretty sure it's the same procedure. Or did they change it between 21 and 22? Wish I had the workshop manual access... Brakes are likely due for service in next 10k, but I may just have the dealer do it.
Old Apr 2, 2023 | 05:36 PM
There are different types!
Old Apr 2, 2023 | 05:56 PM
jaxslk's Avatar
Aha, ty. I shouldn't have assumed the red Brembos are the same between 21 and 22, and the 53 and 63. They are fantastic units for stopping power. What mileage are you at that you're changing pads? I'm just shy of 20k.
Old Apr 2, 2023 | 07:13 PM
Mine has 56,345 miles on it
Old Apr 19, 2023 | 11:05 AM
Nobody here who has the data?
Old Apr 19, 2023 | 12:51 PM
chassis's Avatar
2017 GLE350 4MATIC
Either search this site (probably posted many times) or buy WIS from eBay for about $20.
Old Apr 21, 2023 | 10:37 PM
I did search this site!. Mine does not have the common 6-piston types with the pads removed while the caliper is still mounted. I did buy one Mercedes manual software, a nuisance to install, and it does not cover my vehicle!
Old Apr 24, 2023 | 06:32 PM
One more try: Does anyone here have the data?
Old Apr 24, 2023 | 08:07 PM
chassis's Avatar
2017 GLE350 4MATIC
It appears not. Have you looked into WIS from eBay?
Old Apr 24, 2023 | 08:16 PM
Yes, no luck! As I typed above, I bought a WIS, struggled to get it installed, then found it does not cover my vehicle. I searched Ebay and elsewhere, and could not find any which actually cover the 2021 vehicles.
Old Apr 24, 2023 | 10:48 PM
chassis's Avatar
2017 GLE350 4MATIC
Bummer. A suggestion is to compare the bolts on your calipers to prior-gen bolts and use the same torque spec if the bolts are the same. Ask the guy at the dealer parts counter to pull out a bolt from the prior-gen W166 AMG GLE63 and compare it to the current model V167.
Another idea is to call an indy shop and ask them for the torque spec. Maybe they will tell you, maybe not. The phone call costs nothing.
Generic torque spec tables are not applicable because MB (and Porsche btw) specify torque + angle.
