'23 GLE53 Noise at 1800-2k RPMs
Old Sep 15, 2023 | 05:56 PM
GLE531st's Avatar
'23 GLE53
Question '23 GLE53 Noise at 1800-2k RPMs
Hi All,
1st post, I have a new (10 month old) '23 GLE53 (purchased new in California). Since day 1 I have had an issue with what I can only describe as a hollow whistling noise that only happens when the car is at 1800-2k RPM's. If I hammer the gas it doesn't happen, it's only on normal smooth acceleration, and I can reliably replicate this every single time I drive it. It's at the dealer now as it also had an "e-active body control malfunction" last night, and it felt like the car had zero suspension (which is not part of this post, although reading here, this sounds like a bad problem to have).
Just wanted to check in and see if anyone else has this noise, I wish I could get it on audio, but the noise of the car supersedes recording it with my phone. Will drive it with the foreman if needed as I can replicate every time. Anyone with a similar issue, or anyone know what could be happening at those RPM's to make a hollow whistling noise (maybe some sort of vacuum leak)?
Either way, thanks for reading, glad I found this community.
Old Jul 16, 2024 | 04:25 AM
Moe Fardan's Avatar
GLE 53 AMG
Originally Posted by GLE531st
Hi All,
I have the same issue, have you managed to find out what is causing this, or if this is normal?
Old Jul 16, 2024 | 10:30 AM
GLE531st's Avatar
'23 GLE53
They had the car for a week or so for random stuff, and said they test drove another GLE53 and found it made the same noise. They said, again, they think it's the 48V battery spinning up (or whatever you would call it, charging up?) to deliver power. I wasn't there for the test drive, so I can only put belief in them telling the truth.
Old Jul 16, 2024 | 11:02 AM
Moe Fardan's Avatar
GLE 53 AMG
Thanks for the reply. This does make sense, but honestly, I have been watching some tests of the cars, and I can’t seem to hear the same noise. I have arranged a car test for the same model and will check it myself. I will keep you updated about this.
Old Jul 16, 2024 | 11:50 AM
GLE531st's Avatar
'23 GLE53
Please let me know, I have my doubts and think I was just told this so I'd stop complaining about it. lol.
Old Jul 16, 2024 | 02:12 PM
suby01's Avatar
2024 AMG GLE 53
It sounds like the sound you are referring to is the turbo. This is normal.
Old Jul 16, 2024 | 08:37 PM
GLE531st's Avatar
'23 GLE53
No, it's not the turbo, I've had multiple cars with turbos and the turbo spool/whine is a common noise, this is not it. Really hard to describe the noise, but it is for sure not turbo related.
Old Jul 20, 2024 | 04:40 AM
Moe Fardan's Avatar
GLE 53 AMG
I can confirm that the other car has the same exact sound. I believe its the mild hybrid trying to deliver power. maybe some coil whine . sound like strange squeal or howling
