GLE 53 Coupe - Clunk sound from start - Need Feedback Pleasek
) a "clunk" sound from the rear of the car when I am starting off from a stop. It's not crazy loud, but nonetheless, I thought it was unusual. So, I brought it in, and they had the car for a week. They did a bunch of tests, and also a transmission adaptation (no idea what that is). Anyway, I was advised to pick up the car today, and was told that all is normal. I spoke with the shop Foreman and he indicated he has driven two other GLE53’s that were there on property and found similar “clunks,” which he feels may simply be driveline slack with the all wheel drive system. So, they are classifying this as mostly nature of the beast after all the extended testing. Other than this sound, the car has performed brilliantly, and I am at 2,200 miles.So, the question is....any other GLE 53 coupe owners experiencing the same thing, just to put my mind to rest? Thanks much
However, if your brakes are wet when you park, the pads can rust to the disc, making a clunking sound when they finally release.
"Transmission adaptation" is simply to unlearn your previous driving habits that may influence shifting. After adaptation, it starts to learn your driving habits again and adjusts accordingly.
"I spoke with the shop Foreman and he indicated he has driven two other GLE53’s that were there on property and found similar “clunks,” which he feels may simply be driveline slack with the all wheel drive system. So, they are classifying this as mostly nature of the beast after all the extended testing. Other than this sound, the car has performed brilliantly, and I am at 2,200 miles."
thanks for the reply!
Scott
Yes, I do have the active sway bar option. Thank you for sharing your experience. I have a regular service appt coming up soon and i will be sure to have then check the rear sway bar actuator! I owe you a beer if that is the problem and they fix it! Then I just need to get the transmission shifting issue fixed and I will be happy with it.
Dan
Dan
