HELP Front 360 Camera not working
Ive got a black screen with an image of camera inside a red circle, suggesting my front camera is not working.
Took it to mercedes for a diagnostic who said camera needs replacing and quoted £900.
Managed to get part number and ordered a new camera myself and installed it relatively easily, as its plug and play. the bonnet is closed properly and all other cameras works fine.
However issue is still there, any ideas? Could it be a fuse issue, if so where is this located?
"I learned one thing after removing my front bumper.. Before you disconnect the front Camera, make sure you have disconnected the battery and wait 15 minutes. If you wait this 15 minutes, the car will go to sleep and all the modules will turn off. You can then remove the front camera and install the new one without have to have it recalibrated again."
that is very helpful! Thank you so much, I just hope its the camera thats the issue and not something else I just bought the car. Which camera did you go with? Oem or aftermarket?
hey brother, just replaced with a new Oem camera and I did the steps on removing battery it went to a complete black screen and then later the no camera symbol came back. Does that mean it needs to go to the dealer to get recalibrated?
Hi, did you ever get it working, just calibration right enough? Surely there’s garages that can do the likes as opposed to the dealer?
