Battery Light
Thanks!
C
Thanks!
C
Unfortunately, driving to recharge probably takes 60 mi plus.
A good practice is to have a maintainer (not a trickle charger) that you use monthly to get a FULL charge. Doing that can add a couple years to your battery life.
I use a CTEK, which is the one that Mercedes re-badges and sells in their parts rooms (for more money).
If I'm going to leave my car for a week, it's on the maintainer. Your car is not fully asleep, and it will noticeably drain your battery in 2 weeks for sure.
I am just under 4 years, and I asked the shop to run a load test and it passed. So far so good.
You might get a maintainer, let it do its thing for a couple days, and you might recover. A maintainer is a good thing to have in your arsenal anyway.
I think the battery light comes on at 12.2 volts, So it may not be terminal.
When you put it on a maintainer, do you connect down below the drivers seat?
Thanks!
C
Thanks!
C
But when I pull up the app it'll show me low battery before it alerts me.
I use the charge points under the hood, right in front of the driver.
https://mbworld.org/forums/gle-class...ml#post8793334
Wrote a thread about the ordeal. https://mbworld.org/forums/c-class-w...-readings.html
What is my point? Who knows, maybe its just the car acting up and turns out to be nothing.
Takes a lot of highway driving to bring the charge back up. Like an hour or three.
There are just too many systems awake or waiting to be awake, that draw down the battery more than a couple of miles' driving can recover.
Approaching the car with a key in your pocket uses juice. Opening the door or even the hood uses juice.
I have a limited draw Voltmeter that I use, and I can see the voltage drop from 12.5 to 12.2 just by opening a door and hood.
It recovers gradually over a few minutes, but until the car goes to sleep again, it'll never go back to resting voltage.
One thing you can do to save your battery is keep your key far away from the car. And don't use the Mercedes me app because it wakes up the car also.
My running voltage on the road is 15.1V.
There is a (relatively complicated) way to dig into the service menu to show voltage in the instrument cluster, but I'm not sure if it displays "continuous" or only "instantaneous."
It dominates your instrument cluster so your chosen display disappears.
