Watch-out for this! The oil separator is some sort of over-fancy PCV valve. It is in the valley. My 2021 AMG GLE 63S in at the dealership now because it failed. That caused the rear main seal to fail, and the motor - alternator for the mild hybrid system was drenched in oil, so is also being replaced. The dealership told me today that the motor - alternator is very expensive. They removed the engine and front suspension to do the repair. I found a video stating that the thermostats are also failure-prone, so am having them replace it (the part also is about $750). Fortunately, I bought the 100,000 mile warranty, and it had about 2,300 miles left on it, so my cost will only be for the thermostat failure. Buying this thing was a mistake. Mercedes-Benz needs to get back to making top-quality vehicles.
W205C43PFL
close
- Join DateDec 2019
iTrader Positive Feedback0
iTrader Feedback Score(0)
Liked:6,312 Times in 5,477 Posts
Quote:
Another case of RMS (but a more recent model year vehicle) to report to your thread, forum member @PeterUbers Originally Posted by FStephenMasek
PeterUbers
close
- Join DateJun 2004
- Vehicle(s) I drive2014 E63S; AMS 100 octane ECU dyno tune; EDOK TCU tune; BB intakes; sprintbooster
Liked:3,229 Times in 2,241 Posts
Thanks for thinking of the thread @W205C43PFL
OP - add your car to this database please
RMS Fail Database m17X engines
Also see NUMEROUS threads in this sticky discussing the RMS issue beyond what you've described:
https://mbworld.org/forums/w213-amg/...fixes-diy.html
W205C43PFL
close
- Join DateDec 2019
Thanks for thinking of the thread @W205C43PFLOP - add your car to this database please
Am I reading this correctly 98,000 miles on the car when this happened?
I've been holding onto my m157 2019 GLE 63s coupe because I don't want the hybrid system. Also bought a 2020 E63s because it is seeming the last amg without a hybrid. The alternator motor are pricey
Quote:
Yes, OP says: "I bought the 100,000 mile warranty, and it had about 2,300 miles left on it" so I'm also wondering, almost 100k on 4 years truck? Originally Posted by silver63
ExploreQuote:
Yes. I bought it in November of 2020, and drive more than average. I'll ask the dealership what it would have cost if I'd had to pay.Originally Posted by silver63
I bought it in November of 2020, so it is coming-up on five years old.
Thanks, I searched, but apparently not well enough....
W205C43PFL
close
- Join DateDec 2019
Quote:
Do you mind telling us what fuel you use, oil change intervals, type of oil viscosity and weight used, brand, type of oil filter used, humditiy level on average, temperature on average, short or long trips often (I assume is the latter given the mileage), track or street use mainly highway? Do you tow, usually full cargo or only you and a passenger, etc. All will be good information as a data point.Originally Posted by FStephenMasek
chassis
close
- Join DateSep 2018
- Locationunbegrenzt
- Vehicle(s) I drive2017 GLE350 4MATIC
Liked:4,574 Times in 3,543 Posts
Another MB grenade engine in a long list of grenade engines from MB.
Quote:
None of those things are the problem. It is a too-cheap part in an expensive vehicle. Maybe they saved a Euro or two on it????? In my case, it has been mostly used for easy highway driving, never towing, racing, Etc., and it has always had top-quality oil to M-B specifications at recommended change intervals. Originally Posted by W205C43PFL
ThanksOriginally Posted by PeterUbers
W205C43PFL
close
- Join DateDec 2019
Quote:
I guess every saving adds up but not driving in frequently or neglecting oil changes would cause the seal to dry up quicker I think? Hence why I brought it up and was curious (hence the questions), so we can gather more data. I understand you did not neglect oil changes and you drive frequently and most likely an enthusiast since you are on this forum.Originally Posted by FStephenMasek
The motor and transmission mounts were also found to be bad, so they are replacing them under the extended warranty.
W205C43PFL
close
- Join DateDec 2019
Quote:
Good call. Originally Posted by FStephenMasek
Does anyone know if this type of repair would be covered under the more limited cpo warranty? I imagine they would squirm out of replacing the mounts for free, arguing those are 'wear items'.
Quote:
They tried to argue they were wear items, but I pointed-out that many cars with 200,000 miles on them still have the original motor mounts, and told them I'd be happy to speak with the District about it. That is about the last thing they want, and a good service guy got them covered. Originally Posted by smiles201
This vehicle had already spent too much time at that dealership, as the 48-volt battery failed twice. I got a nail in a tire when it was new, and found that the lug bolt covers were defective, so it had to be serviced for that after parts came from Germany. The most recent change of the 48-volt battery, they messed-up some back seat wiring so the folding did not work, so it had to go back for that. It also had a grabby center differential, fixed with replacement of the oil.
W205C43PFL
close
- Join DateDec 2019
It is quite a job and the dealership probably doesn't want to go through the hassle of claiming the cost after the work done from corporate, good on you on pushing them. Was yours a CPO warranty though? If extended limited warranty it is different which covers way more stuff. Originally Posted by FStephenMasek
They tried to argue they were wear items, but I pointed-out that many cars with 200,000 miles on them still have the original motor mounts, and told them I'd be happy to speak with the District about it. That is about the last thing they want, and a good service guy got them covered.This vehicle had already spent too much time at that dealership, as the 48-volt battery failed twice. I got a nail in a tire when it was new, and found that the lug bolt covers were defective, so it had to be serviced for that after parts came from Germany. The most recent change of the 48-volt battery, they messed-up some back seat wiring so the folding did not work, so it had to go back for that. It also had a grabby center differential, fixed with replacement of the oil.
W205C43PFL
close
- Join DateDec 2019
Quote:
This is a Canadian market list but you get the idea, the extended warranty covers much more stuff: https://cimg2.ibsrv.net/gimg/www.mbw...b5c0de9adb.jpgOriginally Posted by smiles201
Quote:
Its the sleeping giant in every M177 engine. That's a lot of AMG models, including my E63s. It cost me $8k at an independent shop. Took nearly 30 hours, the parts were a few hundred. MB should have recalled. Mb wouldn't even work on it. The Oil separator is a useless emissions part to attempt to save microscopic oil droplets from going out the exhaust. Its part of the Crack case PCV system and it has this little plastic ball valve that gets gummed up and stuck over time. Mine went at 47k miles!!!! If you read these forums you'll see some going at 10k and 20k miles! Mb redesigned the RMS and its much sturdier, but no redesign on the oil separator. AOS, as its called, is a set of plastic hoses that snake from the back of the engine to the front. There is no way to clean them or inspect them without massive labor hours. Another solution would be to replace with an oil catch can, however none exist and the space is very tight for something like that. If you have one of these cars, I would drive it easy and go sell it. Im keeping mine now that I've paid and am on the other side. But, eventually I will sell, maybe a year from now. I dont trust the car. Its a 2018 edition 1. I've had to replace the rear suspension as well for $6k. Fast and amazing handling, but I dont trust the quality. Originally Posted by FStephenMasek
Quote:
Are we talking about the same engines that is in '18 E63 vs '21 GLE63?Originally Posted by DannyXFL
chassis
close
- Join DateSep 2018
Quote:
2018 W213 AMG E63 uses the M177 4.0TTV8Originally Posted by mb4z
2021 V167 AMG GLE63 uses the M177 4.0TTV8
