Dome Lights Removal?
Old 05-21-2009, 03:26 AM
MadLorGLK's Avatar
2010 Mercedes Benz GLK; Black; Appearance Package; Multimedia Package; Panorama Roof;
Has anyone, attempted to remove the dome lights (map lights)?
I've tried but to no avail
Old 05-21-2009, 06:55 AM
NYCGLK's Avatar
GLK 350 / Porsche 993
Dome lights or map lights cuz those are different. Map lights are on in the mirror, dome lights are by the sunroof buttons.
Why would you remove them? Making disco lighting inside? haha
Old 05-21-2009, 07:51 AM
EnigmaAW's Avatar
2017 G63
please don't say your changing the color of the bulbs?
Old 05-21-2009, 09:22 AM
andyf0's Avatar
GLK350 4MATIC
Xenons for the interior lights. Cool!
Old 05-22-2009, 10:54 PM
MadLorGLK's Avatar
Dome lights cover, I still do not know how to remove them, help
I replaced the entire interior lights with LED's (white)
I like how they look
I will try to take pics soon, (been busy)
Old 05-24-2009, 08:37 AM
Sean76NYC's Avatar
2016 C450 AMG
I'm very curious to see how they look, and how you've been able to fit your GLK with LED's, especially without any errors coming up on the dash. If you can, post some pics. Thanks...
Old 05-31-2009, 02:31 AM
louiet3's Avatar
2009 C300 Sport Palladium Silver & 2012 GLK350 4matic Black
Done with the dome light bulbs?
I'm not sure if you already figured out how to replace the dome lights bulbs.
I was searching and happen to see your thread as well as another with a pic on how to do it for the W204. If the GLK dome light is the same then it would easily be removed by using a credit card. Please click on these links.
https://mbworld.org/forums/attachments/c-class-w204/124217d1203224644-radar-detector-wiring-p1010077.jpg
https://mbworld.org/forums/attachmen...g-p1010048.jpg
Here is the comparison between the 4300K LED compared to stock bulb.
https://mbworld.org/forums/members/l...stock-bulb.jpg
Luis
Old 05-31-2009, 08:22 AM
NYCGLK's Avatar
Thanks for those pics.
I like stock better, makes it look "warmer" as GLK has a very "cold" interior as it is.
Old 05-31-2009, 10:21 AM
MadLorGLK's Avatar
Luis
Thanks Luis
I've actually tried that approach many times but am still unable to remove the darn dome light and its the exact same lights
Aaarrgghh!
Old 05-31-2009, 10:46 AM
louiet3's Avatar
Thanks Luis
Aaarrgghh!
Did the credit card cover all the 8 black pointy latches (I don't know what they are called ) shown in the second pic? I did this last night and the dome light assembly separated quite easily.
Good luck!
Old 05-31-2009, 10:56 AM
MadLorGLK's Avatar
https://mbworld.org/forums/2658494-post18.html
here is the link to remove dome lights
i'm gonna try it now see if it works for me
glad it worked for others
Old 05-31-2009, 01:03 PM
MadLorGLK's Avatar
Here is how I removed my dome lights
I'm sure there are different ways of doing this
Here is what worked for me in my GLK
Tools: Credit Card
The LED's that I bought for my interior are not as bright as I would have liked. I've seen alot brighter in other threads. Oh Well.
Oh Yeah, No error message on the dashboard whatsoever
Check out the pics
1) This is my opinion is a crucial step. Make sure you do this first otherwise there are consequences that I will show you later. Use a credit card to get in between the plastic piece that surrounds the mirror and the dome light. Use the credit card to separate these 2 pieces. Then just go ahead and grab the plastic piece surrounding the mirror and pull down gently and slowly but with some force as well.
2) I'm not sure if this step is necessary but this is how I did it.
3) Note, this does not come off easily need to apply some force but be careful. Sorry, I forgot to take a pic of the clips that are holding this piece.
4) Then what is not shown below is that you stick the credit card right in the center closest to you between the cloth piece and the black plastic piece in the center. Then the entire component should go down easily just like the pic. Also I am pointing to the bulb (i'm sure I didn't have to)
5)
6) Sorry, forgot to take a pic of the LED that i used. Here is the difference with stock vs LED (like I said there are much brighter LED's out there than the one I got)
7) Here are the result. Replacing the other interior lights are very easy, I used a credit card as well except for the lights under the mirror, I used a small flat head screwdriver.
8) Note, I tried to show that there is no error message on the dash board.
8) This is the back light. This is pretty easy to remove as well same thing, use a credit card.
Hope this helps someone : )
Old 05-31-2009, 01:16 PM
MadLorGLK's Avatar
Here are the bent cards that I went through before learning from a fellow forum member the proper way of doing this
I dont know how well you can see the scratch or break in the lights as a result of not trying to remove the plastic piece that surrounds the mirror first.
Darn. Hope the wifey dont see this or she will have a cow. Especially since she hates it anytime i modify anything in the car.
Old 05-31-2009, 08:48 PM
jpjolo's Avatar
GLK 350 AWD Steel Grey/Black Interior (3/18/09); E63AMG (5/5/2011)
Hmmm... good thing I didn't force my dome light lens off otherwise I might have cracked it too.
Sorry about the scratches and cracks man. Someone had to do it first.
Thanks for the pics. Very informative.
Old 06-04-2009, 02:52 PM
MadLorGLK's Avatar
Actually it turns out that step 1 in the dome lights removal is completely unecessary...
Old 06-04-2009, 05:08 PM
jpjolo's Avatar
Now you tell me :-) Just kidding.
Did mine. Taking the mirror base cover actually helped as there were two plastic clips from these covers that were attached to the overhead console and mine almost fell off as I inserted the credit card to take it out.
The only thing left are the lights on the mirror housing, and the dome light in the backseat. One project at a time. Don't want to rush and make mistakes.
Old 06-04-2009, 06:07 PM
louiet3's Avatar
How many W5Ws LEDs in GLK350?
MadLorGLK or jpjolo
I was wondering for the GLK350 how many LEDS and for what part are they installed (ie eyelids, foot well, side markers, front dome light, back dome light).
My wife is looking to get a GLK350 so I ordered spares from the last W204 GB. I hope I have enough.
Luis
Old 06-05-2009, 02:14 AM
MadLorGLK's Avatar
MadLorGLK or jpjolo
Luis
(2) eyelids
(2) parking lights
(2) dome lights
(2) map lights
(2) vanity
(1) glove compartment
(1) rear seat dome lights
(1) trunk compartment
(1) trunk door
(2) license plate
Old 06-05-2009, 02:51 AM
louiet3's Avatar
(2) eyelids
(2) parking lights
(2) dome lights
(2) map lights
(2) vanity
(1) trunk door
(2) license plate
Thanks for the list.
Haven't seen a DIY on the map light, would you mind providing instructions if you have done it already?
Old 11-05-2009, 05:14 PM
gdepau's Avatar
2017 GLC300 4Matic SUV
What bulb was used for the rear dome light?
Old 11-05-2009, 11:15 PM
MBRedux's Avatar
Nissan GT-R BE / '12 Ducati-1199 Panigale S / '12 C300-4M Loaded/GLK350-4M Loaded
Great pix... thanks... color temp is too cool for me..(6000K) I prefer warm tones....(2800K) but that's me.
Old 11-06-2009, 11:50 AM
yualfred's Avatar
GLK 350 4matic
Im with you. Actually thinking of replacing the reading lights with warmer color...
Old 11-06-2009, 12:11 PM
JT01's Avatar
GLK350 4Matic - Loaded
Ditto...
Old 11-12-2009, 03:12 PM
gdepau's Avatar
Can you tell me what LED bulb you usewd for therear dome light or where you got it?
Old 11-16-2009, 09:02 PM
pipicyx's Avatar
glk
yeah same here...it would be super if we have a bulb list...(are they in the book already?)
and BTW, where did you get all your leds from?
thanks a lot pal...
Quick Reply: Dome Lights Removal?
