Squeky Breaks
Old Jan 26, 2010 | 11:09 PM
  #101
lulumomo's Avatar
Nissan Murano
Brought my car in, SA cannot hear the noise (they must be kidding). Instead of fixing my problem, they complain about my driving habit.
OMG, I owned many cars before, and never have this problem, so may be my driving habbit is not good for MB.
However, they did the brake service, noise goes away and I hope it is for long time.
At the end, my wife gave me a good advise, when a brand new shinning MB GLK having a squeky noise on the road, only MB would looks bad, not the driver.
Old Feb 4, 2010 | 02:43 PM
  #102
bing1221's Avatar
2016 C63s
I'm having this issue in past couple weeks.
Showed it to dealership, but just can't produce the noise.......
When I drive alone, that squeak come back, very pi$$ me off.
Old Feb 4, 2010 | 03:51 PM
  #103
NYCGLK's Avatar
GLK 350 / Porsche 993
offtopic but yesteray I heard CLS drive by with breaks squeaking like it was 15 year old crap car.
Old Feb 4, 2010 | 04:02 PM
  #104
Duke_on's Avatar
2010 GLK 350 4Matic
They changed the break pads and rotors on my car for free. Since then, no issues what so ever.
Go to your MB dealership and ask them to open a case with MB Canada (or US). They should be able to let you know what the outcome is. Most of the break pads used in NA market is much harder than European models.
Old Feb 4, 2010 | 06:23 PM
  #105
bing1221's Avatar
2016 C63s
When I went to in the dealership, first, the service guy told me "they will order the parts, let me in some other time to fix this issue." They even didn't let me explain what's wrong with it.
Then his manager let he do a road test....just can't reproduce that sound....
Seems, they knew the problem which is a common well-know issue.
Old Feb 25, 2011 | 01:30 AM
  #106
HKPSPORT's Avatar
GLK350
Wink Aftermarket Brake Pad Suggestions?
I love the GLK, but I have this same issue. At 16,000 miles brakes dont squeek they SCREETCH. Really embarassing when your in the drive thru and you pull up to that window. Took it back to the dealer they said pads and rotors were fine but dirty. Charged me $200 bucks to clean them. Two weeks later I'm back at the dealer with the same brake squeel. They keep the car over a week claiming they cant reproduce the sound. I throw the usual customer fit "oh come on" and they refund the $200 bucks. Technically I could have pressed them longer on the manufacture defect issue, but honestly ready to move on. So going the aftermarket route but have no idea where to start. Any suggestions on brands looking for particular low brake dust. As that is also an issue, go figure?
Old Feb 25, 2011 | 08:19 AM
  #107
MBRedux's Avatar
Nissan GT-R BE / '12 Ducati-1199 Panigale S / '12 C300-4M Loaded/GLK350-4M Loaded
Dust is a necessary evil of good brakes. But we use PowerSlot products.
http://catalog.brakewarehouse.com/Sh...Rotors&mode=PA
*Raybestos* brake pads are good quiet products!
Part Details For Mercedes Benz GLK350
Part Number: PGD1340C
Brand: Raybestos
UPC Number : 829352658611
Sub Brand: PG PLUS
Grade: PREMIUM
Material: C
D3EA: no
Disc Plate Length: 5.748
Inner Disc Plate Thickness: .760
Outer Plate Height: 2.551
Outer Plate Width: 5.748
Outer Plate Thickness: .760
Shim: yes
Slot: no
Chamfer: yes
Loose Hardware: no
Electronic Wear Sensor: yes
Disc Plate Height: 2.551
Type: Brake Pad Set
Service: Disc Brake Pad
Now you may need to consider that the noises are not coming from the pads but the pad hardware. So I would replace both sets as well. (They're cheap enough) Now the rotors may be at fault also. (Too soft) So change those out if all else fails. Believe it or not, a neat application of Brake-Quiet always does the trick for about $5 bucks.
PS: See that "no" next to the "Slot" above? That's the reason these brakes develop squeaks over time. No pad manufacturer has a set with a slot available for the GLK at this time since OEM specs require there not be. They'll wise up sooner or later!
Old Feb 25, 2011 | 09:48 AM
  #108
lulumomo's Avatar
Nissan Murano
Update after one year!
The squeeky break noise goes away, and didn't happen this year winter, not sure why but it is gone, I am happy about it.
However, Last winter in the McDonald drive thur, stick my head out to listen to the squeeky break and damage my wheel badly, so it does take a toll.
Old Mar 5, 2011 | 08:17 PM
  #109
mr.mbenz's Avatar
GLK 350X :0
squeeks while reversing
not sure if this is an isolated case.
For a few months and 2 times I have complained about squeaks while reversing.
This is quite embarrassing especially someone is in the car with you.
Sure enough they can not locate the problem nor does the noise reappear. Just got back car from 'service' and .... you guessed it... the noise comes back?
I know brakes squeaks while going forward...but in reverse too?
Never had an issue with other 6 cars owned?
Old Mar 5, 2011 | 10:24 PM
  #110
MKenM's Avatar
2010 GLK Black, Premium 1, Lighting, Multimedia, Appearance and Media Pkg, 2012 Corvette Grand Sport
For the most part rotors are usually going in one direction. When you go in reverse the friction or rub is just the opposite and sometimes you will get that noise. Pads could be on their way out or they might just need a cleaning. Rare but it happens often enough.
Old Mar 6, 2011 | 12:50 AM
  #111
NYCGLK's Avatar
yea weird, never heard my brakes over 2 years. Have you tried doing a few hard stops?
Old Mar 7, 2011 | 01:12 AM
  #112
mr.mbenz's Avatar
GLK 350X :0
thanks MKenM for the insight
and NYCGLK, will try that....
why can't the dealer just change the pads...they can't be that expensive or hard to do? Customer Service the customer....
