GLK performance in snow and cold
The 4 Matic chewed through everything including 3ft snow drifts. Never got stuck... and this is still with my 20s on! (My snow tires get put on tomorrow).
It started every morning like a charm without even plugging in the block.
Got nice and warm inside real fast and the heated seats are the ****!
The vehicle never even got creeky in the cold... and all electronic functions including the windows and liftgate worked fine...
Only one issue... the on and off squeaky breaks... it definately has something to do with the cold.
You never really appreciate a nice new comfy and capable vehicle like you do when it is minus 30 out with tons of snow...
The nav screen will go blank when I start up the vehicle and turn on again after about 5-10 minutes once the temperature in the cabin warms up. I think this might be a standard thing, but don't know for sure. Power windows are slow when closing and power steering is stiff until the vehicle warms up. Breaks still squeal.
Other than that, everything is still fully operational.
I must say that I am very impressed so far...
One thing to beware as my dealer told me is that you should make the side mirrors stay on the outside, instead of them folding in when you turn off the car because once it gets super cold (like the past 4 days), the structure in the mirror COULD get frozen, and stuck in place. He says that this is VERY rare, but has had the occassional problem like that.
Other than that, I feel completely safe in my GLK
Check out the thread about the squeaky brakes, I'm 100% sure its not just the cold weather...
MY only concern is the wipers.... they seem to freeze and get full of frozen snow really quickly! Do we have heated washers nozzles?
What actually happens to the 4Matic system when you turn off the stability control?? Is there a way to lock the 4WD mode or something?
. Got total of 20 inches with some good sized drifts, again the GLK was game. Only thing I noticed this morning was that when I had max defrost set and then turned the heat down on the drivers side, it switched to the AC setting. Any ideas????
I think it switches to AC to remove the humidity and prevent the interior from fogging up.
You may want to disable the side mirrors from folding in when they ice up. Read somewhere in this forum that a dealer mentioned this. I think it's to prevent force being applied when the side mirrors are frozen.
